The Lounge 2021
knucklegary
Well-known member
NorCal
^ although that blue stripe shows Vinh gives support to law enforcement, which is a plus
.. especially if pulled over for citations, every little bit helps 🇺🇸
vinhnguyen54
Well-known member
CPFBA
Why are you holding out on us? Tell us the secret, please!
I have had that issue with older routers in the past and would love some more tricks!
Buy one of these. Plug your router to it. Set it to turn Off 4AM an ON at 4:01AM.
You will be without internet everyday for may be 10 minutes after 4:01AM die to the restart.
You may set up to four restart in one day. It will obviously repeat this sequence every single day.
I only set one reset and my system has been running flawlessly without me having to manually restart.
I noticed my internet works great after restart but starts to slow down after a day or two which I then usually manually reset before.
Techbee Digital Infinite Repeat Cycle Plug Timer Switch with Countdown and 24 Hour Programmalbe Timer for Electrical Outlets, Lights and Home Appliances (120V, 15A) https://www.amazon.com/dp/B086DN9QT3/?tag=cpf0b6-20
stewdogg
Well-known member
Mad Wisconsin
Does anyone have the Jetbeam RRT01vn quad and/or triple Nichia 219b sw45k? How do you guys like it? Do you prefer the quad or triple? TIA
I have the Jetbeam RRT01vn quad in a 219b 3k or 3.5k (can't remember off hand) and it's my daily driver. I love the light. It's not the brightest light I own, but I use it for close up mechanic work and it is great for that. I have it set up with flood optics, which doesn't help the light reach out further either, but does give it a super smooth beam and beautiful wall of light. It has enough light to light up anything I have needed it for.
I personally like the pattern and spread from a quad over a triple, but that might just be me.
vinhnguyen54
Well-known member
CPFBA
Thats just you ahhah JK I too like quads more than triples but it has nothing to do with beams. I just like having more. hahahah
