The Malkoff Front Porch
PoliceScannerMan
PoliceScannerMan
Gainesville,FL
That thing is $$$ nice big display, colored buttons to keep you from hitting the wrong one. Accurate run time test on deck!
kerneldrop
kerneldrop
South
Stay Ready. Me and @thermal guy found a needle in a haystack.
51834886729 ca2d950312 z
kerneldrop
kerneldrop
South
M61NLL Part 2: For the Discriminating Users Wanting a Fully-Charged Battery
I'm surprised the LLLL V2 draws as much as it does compared to the LLL.
My results differ from Gene's numbers. I put fresh batteries in and got same measurements.
I called Gene because I was curious...he said each LED is different and will vary, and those swings from what I measure and what he measures are expected. He said he can measure 1 M61NLL and it'll be 150ma, measure another one just made and it'll be 120ma.
M61NLL @ 6V to compare to Gene's 150ma
51834958414 3bfdcb24bd c
M61NLL:
51833639707 5f35626c80 c
M61LLL
51834937219 88a6b0a58f c
M61LLLL V2
51834937209 557f0407d6 c
M60 Elzetta 235 Lumens
51835317395 23413819b2 c
Fish 14
Fish 14
Took a little Crypto mining profits and finally gave the SST a home.
ekardscribner73
ekardscribner73
Camp Pendleton, CA
That's awesome! I've been wanting to get some equipment like that to do runtime tests and such.
I installed a High/Low ring on my (what I've decided is a) M31LLL 219B MD1. Low is a super low moonlight mode. I estimate it to be less than 1 lumen. I can stare at the emitter and see grid squares in its lit surface. Best part? Low mode draws five ma. FIVE! I'm hooked.
ETA Whoops, that was about kernel's rig. Didn't realize I had missed a thousand more recent posts, lol. Happy Friday
thermal guy
thermal guy
ny
M61NLL:
M61LLL
M61LLLL V2
Nice job man!
kerneldrop
kerneldrop
South
Nice job man!
I now realize to get super accurate numbers you must test your own lights with a simple turn on and see when it turns off. So you're right. lol
I might grab a $25 light meter off Ebay....not to get accurate lumens as it's practically impossible, but to calculate the % lumen drop over time.
That M60 must be an older inefficient LED? I didn't think 235 lumens would draw 720ma.
When turned on the volts drop fast and don't stop dropping.
I also used my negative battery cable and got near matching results, so resistance wasn't skewing the draw...I think those numbers are fairly accurate. Usually the cheaper multi-meters have accuracy issues in the lower and upper ranges....not the mid-ranges where Malkoff lights hang out.
thermal guy
thermal guy
ny
750 for that M60 sounds about right. About 1 1/2 hours with a couple 123’s
kerneldrop
kerneldrop
South
Tight werk Kernel.
What setup are you going with for it?
I wish Malkoff had an 18350 body.
Are there any American made 18350 E bodies?
Oveready couldn’t confirm if they’ll have their E body in stock this year.
Fish 14
Fish 14
Modlite
Fish 14
Fish 14
Lumens factory
neutralwhite
neutralwhite
London Heathrow
hi is there a way to remove and replace the M61 reflector lens - I accidentally touched it with a lens cleaning cloth, looks smudged / scratched up!.
kerneldrop
kerneldrop
South
Edit.
neutralwhite
neutralwhite
London Heathrow
Yes to both. Malkoff sells replacement lenses for $4. To remove you just unscrew the retaining ring and it all falls out. Malkoff sells a tool to unscrew the retaining ring or you can try needle nose pliers or punches that fit in those 2 grooves.
my bad, I meant the actual reflector not the Lens.
thanks Kerneldrop!.
kerneldrop
kerneldrop
South
Lumens factory
The Modlite would be nice.
I've put together a Lumens Factory E1 body and switch before but never get it b\c it's $80 by the time it ships.
The guy with Lumens Factory has excellent customer service. He has the 18350 in pineapple, too. It's not on their site.
I'm bougee and would like a body machined in someone's garage.
neutralwhite
neutralwhite
London Heathrow
right, thanks, - will need to use a shotgun I think to get that reflector out.
damn.
PoliceScannerMan
PoliceScannerMan
Gainesville,FL
I’m gonna either run it on 18350 or 18500. Should be here Monday. I guess I could just do a runtime test with my red LL lol. That’s my only LL.
Similar threads
