thermal guy
Ya grab a 21700 body and your all set.I’ll probably stick with the 18650 head then, since the MD4 body is just way too long for me.
Am I the only one using Malkoff bodies for incan E? If not, plz prove it with pics. thx.
The simplicity, reliability and safety of single cell flashlights is worth a great deal.I’ll probably stick with the 18650 head then, since the MD4 body is just way too long for me.
I can’t help with your question but can we get some photos?I finally got the Wildcat 18650! If not for this forum, I would never have thought to remove the diffuser lens, but I like it better that way. When i unscrewed the bezel ring, it all came apart faster than I intended and there is a plastic retainer or spacer ring i was not expecting to encounter. I put the o ring on the outside, then the protective lens, then that plastic ring. Did I do it right?
Mine doesn’t have a retainer or spacer ring. Just an O-ring.Yes that’s correct ( or at least the way mine is) My favorite light of all times is the wildcat on a MD3 Running 2 2300 18500. I run with the 1% diffuser from a hound dog as it cleans up the beam ever so slightly with out losing any noticeable throw.
Indeed. I called today and was told the same.I believe Gene responded that the spacer ring should go between the diffuser and lens to create a bit of a gap.
When watching the modern version with a buddy he said "would you?".....I pondered that question for years.The original movie ending scene was the best.
In '68, to me, the suggestion of farewell to destructive mankind, and hello to cute mute girl was attractive thoughts 😁
Yep I was incorrect. I went home and looked at mine. That spacer is just to keep the diffuser away from the lens. Sorry.Indeed. I called today and was told the same.
If your module states 3-6cell.. I believe the output is regulated. I think you'll have better runtimes in the red 6D.When watching the modern version with a buddy he said "would you?".....I pondered that question for years.
So if I put the Malkoff Maglite module from a few years back now in my 3D to a 6D will it be brighter? Just curious.
It's a 3-6 cell module in a green 3D.If your module states 3-6cell.. I believe the output is regulated. I think you'll have better runtimes in the red 6D.
Have you thought of converting to li-lion?
The lighter weight will be helpful when running with it in Kung-Fu grip (-;
Not ignoring your request. I took the ring out and now I can't find it.I can’t help with your question but can we get some photos?
I've got those already, got them when i got my Tactician. Getting some more wouldn't hurt, what brand are you running at the moment? Mine are Keeppowers.Buy some 16650’s😁
