TomK85
Love to hear what you will receive as I am planning to buy the sameDid the unshrouded 123 body get updated as well? I ordered a Bodyguard v1 a few days ago. We'll see if it comes with the new or the old body.
How does the new body style compare to the old regarding clip retention? While the old clip is slightly inconvenient hitting the head, it holds on for dear life. How's the new one ?Definitely. Once you get yours in you'll have to upload a pic with a standard MDC e-series head on there. I bet that will look real nice.
The new one also hangs on for dear life, so much so that I loosened mine but that's my personal preference. I like the tiniest bit of daylight between the body and the clip.How does the new body style compare to the old regarding clip retention? While the old clip is slightly inconvenient hitting the head, it holds on for dear life. How's the new one ?
I snagged an old Reflector Style 18650 Hound Dog……..I used to have a Makai, and I forgot how impressive the MCR-38 reflector can be.
I wrote to Gene, and he let me know it's a 4000k XP-L LED, linear driver, 3.7-6V, and driven between 2.4 and 2.8A.
I have a M61L 219b from Illumn and it states a current draw of 250mAh @ 6V for this particular run. How do I calculate the runtime on a single li-ion cell (i.e., how long will a 950mAh 3.7V protected RCR123A Keeppower or 3500mAh 18650 last)?
I believe so. I did a test on a 800 mah 16340 using a Malkoff head on high and the results were pretty accurate.Wow. 3.8 hours is pretty crazy runtime based on the calculator you sent. I imagine the calculated runtime would include taper after falling out of regulation?
No, it's just whatever the mah draw is. So whatever mah the CR123 is that's what you would use. Surefires are 1500mahWow. 3.8 hours is pretty crazy runtime based on the calculator you sent. I imagine the calculated runtime would include taper after falling out of regulation?
Edit: Do I need to adjust the current draw when using this calculator since I'm using a 3.7V cell vs 2x Cr123? So 500mAh at 3V?
If you ask Gene, he does the same capacity and draw calculation, but then multiplies the result by 0.8 for a more "real world answer."I have a M61L 219b from Illumn and it states a current draw of 250mAh @ 6V for this particular run. How do I calculate the runtime on a single li-ion cell (i.e., how long will a 950mAh 3.7V protected RCR123A Keeppower or 3500mAh 18650 last)?
I bought one of those from here a while back. It's my favorite large size Malkoff. It came with a Lee minus green filter on it and gives it a slight pink color and it makes it next to perfect. I actually saw that one posted on eBay. Nice find.Thanks Jfowler: it's one of my favorites but I had never caught that the reflector was one of Dons! And also had never heard the emitter revealed. Honestly the LED is my least favorite part of the light but the rest is so good it's worth it. Thanks the info. Great purchase off eBay!
Thanks for the Lee filter suggestion. I have those on hand. Was hesitant to apply them to a higher output light but may go for it to make it more pleasant.I bought one of those from here a while back. It's my favorite large size Malkoff. It came with a Lee minus green filter on it and gives it a slight pink color and it makes it next to perfect. I actually saw that one posted on eBay. Nice find.
