Kingfisher
Now this is the thread I logged in to see.
Help Support Candle Power Flashlight Forum
Cano, is there much difference in light output when used with 1.2v versus 1.5+v cells? If not, I would opine that the difference is in the internal resistance of the cells. One of the problems with the alkaline cells is that they have a higher internal resistance than decent NiMH and warm up more quickly for a similar *power* draw (emphasised because of the difference in voltage and voltage droop under load). A proportion of the heat is likely to be coming from the cell itself. I would have thought that the regulator would be more efficient with the higher voltage cell, so don't imagine that the additional heat is from that component.
The whole point is moot, however, if the light is brigher with the higher voltage input.
I don't have an EZAA yet but was thinking about getting one for my sister. I bought her one of the Luxeon Civictors several years ago and she still uses it. Probably time for an upgrade :candle:
Andrew
Andrew
Andrew
I have one original EZ AA and one 'revised'.
These are my luxmeter readings at 1 m (min/max) with three different batteries:
Original EZ AA:
- NiMH = 60/1900 lux
- alkaline = 80/1900 lux
- lithium = 110/1900 lux
New EZ AA: 130/1680 lux regardless of the type of battery
What they did to the original circuit appears very clearly here. 😉
Interesting 10min on High with NiMH is hot. Sounds like the heat with these other cells is crazy. Good thing I got them for use with eneloop power.Oh, btw, it is definitely the cells that are causing this heat, for sure.
Kilovolt, is your new E.Z. the w version?
