The new little NiteCore: "EZAA" Part 2
Candle Power Flashlight Forum
Help Support CPF:
Thanks good to hear that the brightness is a bit brighter than the LD01 on low. 12 lumens should be nice. It was bit bit disappointing to hear that the original release was no brighter than on E01 - so this is good news so far. I need to reorder one.
Just got my delivery today!! Two days from Atlanta! Not bad.
Initial impression was, "that's really small for a AA". Popped in an Eneloop and was very impressed. The beam has a tight uniform hot spot, as is the spill. Neither quite as wide as an L0D. Not ringy in any disagreeable way. I've only been able to do some ceiling bounce comparisons. Like Chibato said it's a bit brighter than the L0D on low. Much brighter on high. In fact, on high it matches my LF3XT very closely. This EZAA is has a cool emitter. Right now I've got an old worn out AA in there that shows no difference between low and high. Still a useable beam and it fires up again after shut off, so this may prove to be a good battery drainer, if you are so inclined (like me).
Operation is better than I expected. To go from low to high only requires maybe 100 degrees of turn. Not at all like that video that seemed to show a full turn or more. With the Eneloop it's showing a good bit of the brass collar in the just off position. Maybe they are tall batteries. This is not a problem, but perhaps a cosmetic issue for some. 4Sevens' little USB charged AA gift is definitely shorter. I'll give it a try as soon as it's charged up.
It's a good looking light, and the knurling is great. The four holes and a slot in the tail should be very accommodating for your personal keychain/lanyard setup.
Finally, here's some pics of what's in the box and a size comparison pic with a few other well known lights. I'm looking forward to the real reviews.
Geoff
Thanks for the pics Geoff!
I had forgot how small this AA was. Looks great! Someone else posted in the MP forum that they appear to have corrected the long travel required between modes. This is really good news.
Looks like they do have a winner. Hopefully they will work on an update with 3 levels and a clip. I ordered in March, but canceled the standard cool-tint order, so I'm anxiously waiting for them to start shipping the neutral tint orders.
:popcorn:
Geoff,
Thanks for the comments and picts. I wondered if the gap was normal. On the rechargeable battery. I have had it plugged in for 3 hours. Any idea how long it takes to charge?
Flying Turtle are you one of the beta tester guys? I didn't think 4-7s was getting the EZAAs in until after Memorial Day. You got yours earlier than I expected them to get it.
No, I'm not a Beta tester. Just got lucky. 4Sevens started sending out the first batch, I guess to pre-order folks, on Wednesday.
Btw, dagored, I've had the USB battery plugged in now for almost 3.5 hrs. and the light is still on, so I guess it's still charging.
Geoff
Edit: The USB battery did get charged, but I missed the finish. Best I can say is it was done sometime between four and eight hours.
Good news. Well I hope I'm still on the pre-order list. Time will tell I guess. Didn't see any gift from the postman today though. Forgot if he ships USPS or UPS.
I pre-ordered on 3/30/09, and guess i was fortunate enough to be in the 1st batch 4sevens received. I also live in Atlanta, so it only took Mr. Postman one day to deliver. It took long enough, but I am glad I didn't cancel. I think Nitecore got it right.
He ships USPS. I didn't think it'd get here till this afternoon (when I needed to be at work), so I headed in at 0800. You can imagine my frustration when I checked USPS tracking 10 minutes later and it said "Delivered -- 08:03". 😡 So I sat at my desk thinking about it all morning, instead of playing with it all morning. But I have it now, and I like it. :twothumbs: Guess you should get a shipping notification pretty soon.
Nice size comparison Flying Turtle. Next to the Fenix L1T, it makes it look like the EZAA and L1T can't be using the same battery - but they are!
Nice shots.. still impressed how can a AA fit in there. I would love to see how much better does the revised version perform... but 10 lumens for 20 hours still sound like not enough, compared to a fenix L1D.
Just tested the throw off the deck, and it does a fine job. Again it seemed to be about equal to the LF3XT. Both of these come up a bit short compared to the L1, but not by much. I eagerly await reports on low runtime. It seems to be a nicely chosen level.
It is hard to imagine there's a AA in this light. Here's one more pic of it next to my other smallest AA, that's now looking a bit chubby.
Geoff
Just checked 4Sevens website,
and it STILL sez:
Low Mode: 15 lumens for up to 20 hours
Is this statement no longer accurate ?
If so, they'd better change it on their website.
😕 _ :huh2:
_
This rating may be fairly accurate. It's definitely somewhat brighter than my L0D Q4 on low. It is rated at 11 lumens, so 15 could be close.
Geoff
I have to say I'm very happy with the two levels on this little light. The low is Just a bit brighter than my LD01 on low and the high is almost identical to my D10 on high. I really would like a clip for this one. I think the weight of the battery is going to keep this off my keys.
Isn't the E01 supposed to be a solid 10lm reference? My EZ-AA (cool white, so rated at 10 by Nitecore), running on an Eneloop, matches the E01 as near perfect as I can tell in a ceiling bounce. IMHO, no way it's 15 lumens.
High was a little disappointing at first -- then I remembered when I got it out of the box, I had grabbed the first AA that came to hand (an alkaline, and a partly used one at that) just to fire it up. Found a charged Eneloop, popped it in, and now bright is brighter. 😀
For another reference point on the brightness of high: it's brighter than an Akoray K-105's high from NiMH, but dimmer than the K-105's high on LiCo. (My K-105 will go substantially lower; although I've heard reports that some K-105s only go down to about 15lm, I think it's an issue with programming technique. The high is programmable separate from the ramp, so it should be a solid reference.) I find the Akoray a convenient comparison because it's beam profile is the most similar (almost identical, even though it uses a substantially larger reflector), reducing any potential variations in ceiling bounce.
Cool thing about it: the head knurling is grippy enough to use momentary-on by twisting it just off, holding the light against your palm with the head between thumb and forefinger, and pulling it down to take up the slack in the threads. Better yet, you can pull the same trick with high, by twisting it just down to low, and using the same technique (a little more forcefully, since the foam is more compressed). For some reason, I find walking around with it on low and randomly giving momentary-high bursts rather entertaining.
EDIT: One more thing, on mine, there's about 2/3 of a turn from off/low to low/high. Not bad, although it could be less -- it's easy to feel the increasing pressure just before it goes high, so there's no way one of these is going to have accidental overruns into high, even if it had only 45 degrees.
I just got me EZAA today and in light of a full review I'll post my quick thoughts.
* High and low settings are well spaced. Low is about equal to the 8 lumen low on my Ra CGT which is about the same as the "12 lumen" low on my L2DQ5. The high is also about the same as the 100 lumen high on my Ra Clicky. Note that it's hard to make direct comparisons because the beam patterns are so different. My raw is pure smoothness with great flood, the EZAA seems to have more throw.
At this point I'd like to point out that in every day use I either use the high or the low on my ra clicky, so I'm happy with these settings.
* Beam pattern is not so great, there is quite the dark ring around the center spot. I guess this should have been expected with a XR-E and such a small reflector. I wish they would have went with the XP-E.
* Tint is leaning towards violet which I am personally okay with as far as cool tints go. All in all I'm VERY glad I ordered one neutrual tint for EZAA for myself (this on is for the lady).
*It is nice and compact, would make a great EDC if it had a clip, not sure if it's small enough to replace my LOD on my key chain though. Time will tell when I get mine.
Most lights are not valid reference points except the Ra Clicky, which is why I made reference to the levels on my clicky. Still it's hard to tell because the beam patterns are so different.
