Modernflame
Where can I get a new, genuine, SF Z41?
Very nice results Woods.
Does anyone have any interest in M61 425 on 2x Eneloop Pro? Output starts at 15lm...Otherwise i will take the remaining current draw readings and get ready to send this module back to its home
Ok, this will be the last test i do on this module. Then i will work on m61 325 for the rest of the comparison tests.
I probably won't run it out as Woods did. But i will run it to get the main idea
Currently, the only Malkoff devices with PWM are the MDC's. Everything else uses the resistor ring. I have no direct experience with the v1-v5 wildcats.
I wouldn't suspect it's very efficient, and certainly not as efficient as a regulated mode on a multi-mode light. I think the last time I measured current on low for a M61N on 1xLi-Ion the draw was ~17mA. At that low of a current you're looking at days of runtime. How relevant is efficiency for most people's uses at that level anyway?
That mirrors my experience with the L and LL. My M61NL on low (stock resistor) draws 16.9mA @ 4.2V, 37.1mA @ 6V (2x123), and 3.4mA @ 3v (two NIMH). My M61NLL is similar: 16.5mA @ 4.2V, 37.1mA @ 6V, and 3.3mA @ 3V. Both modules draw just over 71mA on 9V (3x123). Surely some of the potential is lost as heat...that's what resistors do. But as you said, at these levels, it's largely inconsequential. You have days of potential runtime in any configuration here, and in true emergencies you can get by with 3-5 hours of light per night—less if you're content to sit in the dark and only use light when you're moving.
some of the more interesting configurations are a body that can take 4xAA cells, twice the length of 2x1800/3x123, which is 3x18650.
The runtime has to be greater than a 2xAA configuration. And the lumens also.
I wish there were other draw numbers to compare to. I remember 4/7s used to have the draw. Granted it probably doesn't matter as the longest power outage I had was 7 days and never changed batteries on any light.
