The official PKDL thread
Candle Power Flashlight Forum
Help Support CPF:
Re: Paul Kim's PK-PR1
What i see is really pleasing on the eye, not sure what you guys are finding with yours:) Mine is more towards the yellow side which i much prefer(slight) over any blue tint normally associated with CW.
Other than being unsure about the clip(serves a purpose, more on the form side and probably change my mind over time), there is not a single thing i dont like about this light..............nothing!
I dont know about you guys, i just cant stop looking at it and admiring the design, followed by feeling the knurling. Its not a light i can pick up and use, then put down................its a pick up, use and keep hold of............till i need to free my hand up to type this..................the end as i need to hold it again :laughing:
Great pics! Also agree about the tint. I was very happy to avoid the overly white to blue tint. As mentioned before, I really appreciate the ergonomic practicality of the relatively hard machined edges. The great aesthetics are extra.
I know there are others out there but I know PK has put his heart and sole in his lights. /QUOTE]
+1 For sure
Still cant get over the size!
Thanks roger, i am yet to just pick it up and use the PR1...........its caressed and admired every time!
Guys, there's currently only 1 PL-2 Rainbow and 2 PL-2 Silver left on Amazon right now!
Here's 2 of them DK.
Congrats bykfixer... a pair of bouncing baby twins.
It went down something like this...
I'm sleeping comfortably when PR-1 on the bedside table starts flopping around and flashing.
Me: "What?!?!"
PR-1: "mailmans here"
Me: "shut up and go back to sleep"
5 minutes later...
Same thing only 2 flashes of light in my face....
Me: "What!?!"
Big Bro FL-2: "Mailmans here, get up and see if the baby's here!"
Me: "ok, lemme get some coffee and take a leak"
Go to mailbox and yup box is here.
Set it on counter and do my first thing in the morning things.
I get back and these knuckleheads are trying to burn a hole in the box.
Me"stop it!, you'll kill the baby... move, let me do it"
Chorus: "ok, ok, sorry Dave"
Chorus: "take a pic, take a pic!"
Me: "let me clean up the peanuts guys"
Ever since they've been bugging the crap out me with suggestions...
"Take a pic with a Solitaire, do some beam shots, try the microstream clip...."
Some thoughts:
Easy enough to open the box.
You know it's a PK when a normally 4 sided box has 3 sides.
Crack it open and insert a Rayovac
Note the flat, easy to use keyring.
PK even thought of that. Just the right stiffness in the flat ring where the ends are just right for grabbing while the flatness allows ease of key being slid over it.
Brass spring on the inside of the smooth barrel.
Very light orange peel.
Note the light is round, but still has anti-roll. See there are cuts all over the place. Like the PR-1 the slices cause it to resist rolling without an actual anti-roll look.
Twist the head counter clockwise a few degees to turn it on.
Twist clockwise to turn it off, repeat counter clock-wise for low...
Twisting to on closes the gap and completes the circuit.
Simple genious (as usual)
Twist a few more degees from off for no turn on concerns.
Loved the end treatment.
Another Kubotan by the Photon King.
Suitable for framing brochure.
After wrinkles are ironed out anyway...
Solitaire: Meet your new King.
With the PR-1 sibling
Versus a bunch of vintage goodys.
The beam you ask?
The tint is pretty close to the PR-1 and FL-2. PK says 6500 in the brochure. But it seems more like 6437.5 or in others words a very white beam with an ever-so-slight hint of warm. Think beam from an ROP'd Mag with fresh off the charger rested batteries.
Folks: it's a triple a light with a tiny reflector. So it aint gonna signal an airplane. But the deep reflector will amaze how far it actually throws. Right up there with the PR-1 on medium. Light up stuff you wanna see for 75' or more easy. Great when you aint sure what went bump at the other end of the average home.
The narrow reflector causes more a pencil beam look versus the more floody looking PR-1 on medium.
The beam on high
Low
You'll note a slight tint change... to the warmer end of the kelvin scale.
This is another home run by PKDL. At $36 the average user may say "too much". But what you get for $36 is a Mag Solitaire sized flashlight with a giant output. A solid piece of craftsmanship that will continue to amaze your friends for a good long while.
The CNC'd edges are crisp enough to provide sure grip while not feeling sharp at all. When you hold it the weight is noticed yet it is still a gram counter:
With the PR-1 you first notice how many grams are not there. With the PL-2 you notice how many are.
It is noted as getting very hot. Well I noticed it gets warm after a couple of minutes. Not a scorcher, like it doesn't blister you or anything...
But when PK says not for use of extended periods I figure using it for... say tying a fishing lure knot is ok. But for use under the hood for the life of an hour or so of a Rayovac will be cooking the emitter and reducing the LED lifespan to about the same as an overdriven light bulb... hours instead of years.
This thing will make a great back up to the PR-1, which is a great backup to the FL-2.
With PKDL lights 3 = 3, but being prepared is what it's all about, right?
Throw pix and wall shots later...
It's later.
I did some total size of beam pix with the PR-1 and PL-2. All settings used for that.
Then a couple of pix to show the PL-2 out throws the way floodier PR-1.
I was pleasantly surprised how far it threw well.
PR-1 vs PL-2 high beam:
Huge!
Pencil with good spill
PR-1 on medium:
Hard to tell it isn't still on hi beam
PL-2 vs PR-1 low beam:
Plenty useable at 25'
Mighty bright for 10 lumens.
The throw surprised me.
PL-2 high setting
PR-1 nearly 2x brighter medium setting
More area lit for less distance.
Somebody used the word 'conical beam' to describe the PR-1. Great word.
I hope somebody can think of one just as accurate for the PL-2 beam. It's not a pencil, yet not a flooder.
For now I'll call it "the gnarliest 1aaa flashlight beam I've ever seen"
I'll use it a few days and share some thoughts in a later post.
So......
Should we start a PL-2 thread or merge one? Or just keep 'em separate?
Very nice, love the mod..............great idea!!!
You know when your a flashaholic when you get a message on your invoice thanking you for your custom:poke:
Welp no more black PL-2's for now...
Hey PK- we need more black PL-2's at Amazon please!!
Silver too...
2 ti ones left... nope 1... wait, back up to 3. Huh?
Very cool posting links!!!!
Thank you.
(Hope it's ok)
Was going to say that all 3 are showing 6 in stock again.
Miyagi, I seriously doubt you'll be disappointed.
Big bro explains to baby bro the big orange thing.
Meanwhile little bro looks on remembering the times his low setting was used to assist a vintage flashlight restore via peering inside a barrel to hunt down corrosion and destroy it.
Aha! We have the same Samsung remote control. LOL. Time to sell my other lights to fund a big purchase. Seriously, I read this thread about 3 times to learn about PK and his lights. :huh:
PK is an industrial engineer who has made huge impacts on the flashlight world. Once at SureFire, now through his own company.
I don't want to go into a lot of detail about it because, frankly I'm pretty new to the modern flashlight world and only know what I've read on the internet about his time at SureFire. Details are fuzzy and you know the old saying about what you read on the internet...
I discovered his FL-2 one night while reading here and soon after acquired one. I saw it was an expensive light but found one at half price at Bulls Eye. Thinking is was a fake I bought it anyway. Then I saw on the PK facebook that they are an authorized seller. Woohoo! FL-2's for half price... I bought a few.
It is for all intents and purposes the one that started it. It was a limited edition light that can still be obtained at Bulls Eye. Being a product of 2014 it's "only" 650 lumens on high with a very useable low setting. I forget the number, but it's like 15 or something. In 2016 it's still my benchmark. It's one of those things you have to experience in person to understand how profound it was/is.
There are threads here about it, with numerous negative comments based on not understanding just how profound it is. I am a big fan of Streamlight. I'm all in on Malkoff stuff too. But the PKDL products are leaps forward in time. You see numbers scroll across the screen touting huge outputs from tiny fuel cells. Numbers higher than PKDL products. Those numbers indicate a breif period until the laws of physics takes them to safer levels. PK numbers are like Malkoff and Streamlight in that when it turns on you get those numbers... and they stay that way as long as the fuel cell allows.
PK does "white beams". Always has and probably always will. Back in his SureFire days folks wanted bright, brighter and brightest. White beam without colors was the ultimate goal. He obtained that even with incandecent products (with fresh batteries) and at SureFire they had regulated incans to keep the beam as white as practical as long as possible.
These days fashion asks for more color in the beam... they want less white. PK sticks with his original purpose, which is to provide the best lighting possible in tactical situations where life and death are part of the routine. Cops, soldiers, and anybody ever needing personal protection are who he has in mind while at the drawing board, in the lab or at the factory.
Others use tried n true methods to make fine products for tactical scenario, still others go for sales. Meanwhile PK goes way out on the limb to provide a reliable product that others will be duplicating somewhere down the road.
Ok, that hopefully catches you up a little more.
A random question.
What do you guys use to clean your PR-1 and other PK products (and other high-end flashlights alike)?
EDC'ing my PR-1 literally 24-7 and the attention it gets from many people left not only dusts but also "fingerprints" (visible or not) all over...
I pretty much use wipers and nail polisher on everything but I just thought I would check with you guys on this..
Just a PR-1 care question...
PR-1 sure gets attention from people.
Thank you for the great post, Bykfixer.
I can't agree more. PKDL products definitely timeless masterpieces. I literally look at it as a masterpiece of contemporary [engineering] art.
Some vehicles end up in junk yards while certain vehicles end up in classic car showrooms after 30 years.
Some flashlights end up in bins while PKDL flashlights end up in CPF members' shelves and etc.
A random question.
Dust n dirt are afraid of my PR-1.
Nah, seriously, pocket carry seems to keep the body and lens pretty clean. Any lint gets wiped off with an old toothbrush and tootpick if needed.
In the gaps between tail, body and head lint tends to stick to the lube, so I brush that off with a toothbrush and smear a bit of Honda approved rubber trim grease called Shin Etsu grease.
Paul Kim's PK-PR1
A random question.
I personally like Sentry Solutions "Tuff-glide". I use the spray as well as their "Tuff-cloth". They advertise it as "body armor for your gear". Of course they also advertise "used by Navy Seals" which I would have ignored, but it was a Navy Seal that first showed it to me. I have a religion for my lights that requires regular scheduled maintenance (6 months in storage, 3 months or more often if in the edc rotation).
They get the toothbrush to remove any lint/dirt/blood/mud/yuck-what is that? Then deOxit on springs and contacts, threads lubed with Sentry Solutions Tuff-glide, "O" rings lubed with Nyogel 760G, batteries charged to the appropriate level, and a final rub down with a tuff cloth. Good to go...
Wow! At that angle it looks like it has a ton of tiny tritium vials all aglow. Very beautiful. I told PK his work reminds me of what a flashlight would have looked like if it was designed by DaVinci....
I think PK said somewhere here at CPF he's a DaVinci fan.
I really dig the silver version.
Sometimes big things come from small packages.
The PL-2 for example...
