archimedes
Was mostly interested in the Samsung emitter. That is super helpful info, thanks.
I'm sure others have done this, but I now found a great solution for my main issue with the UI.
In the G6 (or G7) mode bank, I program H1 to "low" and L1 to "high" which removes the timing needed to simply single-click to a low output. If I want high output, I can "click-hold" , but I don't get blasted if I miss the timing when I want low.
If, for some reason, I want to swap back to a "standard" ZL UI ... it is rather easy to swap H1 to H2 and L1 to L2
I like this system much better :twothumbs
I was quite impressed with the Samsung. It had a noticeable yellowish corona when used indoors but outside it was hard to tell it apart from my favorite 219b. It did have some tint shift at lower levels, but not much. Slightly more than with 219b but definitely less than an SST-20.Was mostly interested in the Samsung emitter. That is super helpful info, thanks.
My SC53w on High gets hot on Eneloop.
My SC52w on High stays cool on Eneloop.
What is your guys experience ?
Nice, I'm really liking this system.Exactly how I set mine up. Flip the low and high positions. Also removes that pre-flash issue.
Question for the zebra junkies. Has anyone abandoned their regular zebras in favor of the headlamp style? Just curious if you’ve found the right angle lights to be overall better for you over the straight. I’ve got my first zebra headlamp en route but always wondered how well I’d like using one when it’s not attached to the head strap.
Nope. To much of a hassle taking it out of the strap, and I've always got a few other regular Zebras on hand, so it's just not necessary.Question for the zebra junkies. Has anyone abandoned their regular zebras in favor of the headlamp style? Just curious if you’ve found the right angle lights to be overall better for you over the straight. I’ve got my first zebra headlamp en route but always wondered how well I’d like using one when it’s not attached to the head strap.
