NutSAK
...or click-hold from off to advance through low to medium. If this method is used, it's very unlikely you'll accidentally activate strobe.
Using the standard UI (G5), from off, a double click will turn on medium, then a click will turn it off. I don’t see the point?
Dang, I had no idea you could do this! Thank you. Just changed my SC64c LE to never bug me with strobe again.![]()
Yes it’s hard. Why would you turn it on medium quickly using a double click, just to turn it off half a second later (and activate strobe)?And then a fast single click will on strobe instead of off. Is that so hard to understand?
For me accidental strobe happens most often when I turn the light on with a single click (which I have set as medium brightness) and then double-click "too soon" to switch to my medium sub-mode.Why would you turn it on medium quickly using a double click, just to turn it off half a second later (and activate strobe)?
Yeah, this is totally a thing. Not something that happens often, but can cause quite a bit of annoyance when it eventually does.For me accidental strobe happens most often when I turn the light on with a single click (which I have set as medium brightness) and then double-click "too soon" to switch to my medium sub-mode.
This sounds quite like the "you don't like it because you just don't understand it" fallacy.With absolutely no disrespect directed at you, that's seems to be a huge issue with casual ZL users. They criticize the UI, without ever learning its full capabilities.
Regardless, I'm glad this was worked out and you can enjoy your ZL. It's really the best UI I've ever used in a flashlight.
I have two of the H600c. The beam really isn't the best. It is hard to capture, but the center of the beam is slightly blue, and there is some tint shift from the corona to the spill (which are both rather yellowish). Both of my H600c lights exhibit these beam defects. I used to have the H600Fc variant, and the tint was much more uniform with the frosted lens, though still rather yellowish.Does anyone have a new h600c mk4 with the 4000k xhp50.2? If so how do you like it and how is the tint compared to other high cri 4000k emitters?
I’m thinking of that model to give zebras a try, but still not 100% sure yet.
I wish Zebralight would come out with some new flashlight models.
It's been literally years since they came out with anything new.
