Mr. LED
Yes, that we know. What we want to know, is how the throw compares between this HI version, to the older HI versions (SC64w HI and SC600w IV HI).
id30209
Croatia, EU
wow, looks great
does xhp70.3 hi exist?
they should make a sc700d hi
Yes…diy
XHP70.3HI 6500K 80CRI
Nichia 519A sm573 dedomed
47 Turbo with domed Nichia 519A sm573
SYZYGY
Yes…diy
nice one! i want to do it to my sc700d.
any particular reason you went with 6500K? just asking in case you have an opinion about the range of 70.3HI offerings. simply preferring cold temps is a fine answer, though.
this is the only report i've seen of someone taking one apart:
any tips to share beyond that? seems like removing the bezel and desoldering the main board from the cathode-spring board are the main challenges. reflowing sounds possibly annoying too without a preheater since its pads are on both the pcb and the copper block. can't just reflow it by heating the copper block alone.
id30209
Croatia, EU
This SC700 is not mine, i just did emitter swap for it’s owner.
I had 2 of these emitters just for testing and to my surprise the owner decided to go with that temp. Once lighted up i was left in WOW.
This specific emitter is the first Cree XHP70 (all gens) that don’t have any hint of ugly yellow corona. Yes, even XHP50/70.3 have it :(
About modding, nothing else to add what Loneocean haven’t said it. Maybe that i’m using 20$ hot air gun instead of hotplate(?)
markr6
I'm hurtin for some new ZL action. I wish they would come out with some new stuff. But honestly, there's not much room for improvement. I'm still happy with my current collection.
Outdoorsman5
North GA Mountains
I received my new SC600w IV Plus HI (3 of them). The beam profile is almost identical to the smaller SC64w HI (discontinued light) with one more higher output mode (around 2400 lumens I'd guess --- as of the writing of this, Zebralight has not yet posted outputs for each level.) ZL's website says the beam type is 80 degree spill and 9 degree hot spot. I'd say it's really 80 degree spill and 10 degree hotspot like the SC64w HI. The older SC600w IV HI beam profile, by the way, was/is 80 degree spill and 8 degree hotspot, and I'm pretty sure the smaller SC64w HI was/is 80 degree spill and 10 degree hotspot (both are 2 of the greatest lights ever made to me and my son for the last decade+!!)
The older SC600w IV HI has a tighter and more throwy beam, but it tops out at 1400 lumens (still really great though). Comparing the the highest output of the older SC600w IV HI on max (1400 lum) to the new SC600w IV Plus HI on max (around 2400 lumens), the throw is a similar distance between the two lights since the newer model is a decent amount brighter, plus the overall spill is brighter too on the newer model. Some might like the older model (a little bit more) for the more throwy hotspot with less of a blinding spill (trail hiking/running for instance), and some will like that this new light has a little bit more flood than the older model with admirable throw (similar to the SC64w HI.)
My perception of the additional 1000ish lumens on the newer model is what you would expect. It appears to be around 15-20% brighter to my eyes than the older model (2400ish lumens vs 1400 lumens. So the math on that is: 1000ish extra lumens divided by 1400 lumens = 71% brighter on paper, times the expected 25% perceived difference in increased output = 17.86% perceived increase in output). In other words, increases in light output "appear" to our eyes to be only around 25% of the overall additional output (hope that made sense to new folks, but most reading this already knew all this.)
This new SC600w IV Plus HI is very interesting. I like to use my HI zebras when hiking/walking into the evening, so I can see farther ahead than with a standard flashlight. The older SC600w IV HI punches through the dark a bit further without blinding me with a bright spill, but the hotspot is a bit too tight for closer in. I usually leave my slightly less throwy SC64w HI at home when backpacking since it doesn't throw a beam as far, and I'm already wearing a headlight providing plenty of flood (either an H53w or an H600w Mk IV). This new SC600w IV Plus HI offers more of a distributed beam, and with the higher output, it appears to reach out as far as the older version with sheer power. This new version might be a better option when walking on the beach at night or walking in wide open terrain, so the spill (when on max) doesn't blind you (the spill is quite nice on all levels though once your eyes adjust.) It has good throw but more flood than the older model, so I might not need a headlight on my head while I'm backpacking into the night when using the new model.
For the tint nerds out there (I'm sort of one too), the beam color of the new SC600w IV Plus HI is not great. Out of the 3 I bought, one is a bit greenish, while the other two are an ok white. None of the 3 new lights have the nice warmish looking beam color like the older SC600w IV HI or the SC64w HI (bummer). The tint on these new lights look just like my older SC600w Plus (not HI) if you have one of those.
I'm keeping all 3 lights though. The greenish one is only slightly green, and I'd still use it or hand it off to a friend -- We've had friends and family come to visit us here in the North GA Mountains, and we take them to our favorite sunset spot on top of Mount Yonah. It's baffling to me, but NONE of them EVER think to bring their own flashlight for this hike (1.5 hours up in the daylight and 45 min back down in pitch black). But it's always a whole lot of fun to put an SC64w HI in there hands, and will now be fun to put an SC600w Mk IV HI in their hands for the hike. These lights make good conversation pieces. They also beat the crap out of using a phone light to cover the 2.5ish miles back down in the dark.
My Conclusion - Once again this beam profile (spill and hotspot) looks a whole lot like the SC64w HI but with one more higher output mode. I consider the discontinued SC64w HI to be the BEST all-around flashlight ever made as it offers a good balance for every day use (not too throwy and not too floody). I have considered for years that the older SC600w IV HI is the BEST backpacking/trail running flashlight ever made due to the extra throw with a reasonable amount of spill (all of my other throwy lights don't have enough spill and therefore get left at home most of the time, and all of my floody flashlights get left at home too for the opposite reason though.) This new SC600w IV Plus HI is an EXCELLENT "in-between" model like the SC64w HI always was. One could argue that this new model does what both the older SC600w IV HI does with beam distance and what the SC64w HI does with a combination of throw & flood - a nice marriage of the two lights. Glad I bought them, and I hope this helped you!!
I'm going night hiking up next month, and I will report back on my impressions of this new awesome light from ZL.
SYZYGY
even as a ZL fan, sometimes it's hard for me to keep the meaning behind the model names straight.
what is Plus probably supposed to mean in sc600 context again?
Outdoorsman5
North GA Mountains
The names are confusing. The "Plus" refers to the use of either the XHP50.2 or the XHP50.3 LED's. These LED's push 2400 lumens compared to the previous LED used in the SC600w MK IV HI that pushed 1400 lumens. You probably already know this, but the large 50.2 and 50.3 LED's make the light less throwy compared to a smaller LED like was was used in the previous SC600w Mk IV HI. Hope that helped.
Repsol600rr
I just received my sc5c mkii le. What a massive improvement in tint from the sc53c. I'm super happy with it. The size difference is noticeable but being much smaller than a 64 series I think it'll be OK if I decide to carry it though I'm trending towards 18350 or 16340 sizes for carry these days. It's much brighter as expected. Overall very pleased. I'd be happy with this emitter in the 53 format in the future if they decided to do it. Might get a h53c le to supplement my older h52w.
SYZYGY
thanks, i see now. and the non-plus was xhp35.
Repsol600rr
Well, unfortunate I seem to have an issue with my sc5c mkii le. No mode seems to activate with any consistency. At first I was having issues getting h1 to work at full brightness. I tried four batteries and it wouldn't get brighter than low medium. But would still cycle LMH just at reduced power. Eventually is just ramped itself to full power. Now I can't get it to go to low. I've tried in g5 and g6. If I do double taps to get a different sublevel it just flickers and doesn't work right. I'm not sure what's happening here. But it ain't right. First zebralight issue I've had. This one's gotta go back.
