ven
Manchester UK
Depending on the light, undoing the tail cap a few MM to break contact ,keeps the tail cap on the O ring/s. By this ,there is still resistance(compared to being undone a few threads anyway). Never had a tail cap budge from being undone, not to power up or actually physically come off. That would take several full rotations which although not impossible, very unlikely. When locking in, there is a noticeable amount of resistance you would expect from sealing with an O ring. IMO it’s still the best method for locking a light out, personally prefer it to elec lock outs.
Touch wood, but not had any issue so far with my ZLs for accidental activation. Yes pocket carry, but what pocket a light is carried in,stays just for that light. Certainly no keys or coins get mixed in with an edc light(or any for that matter other than key chain lights).
moozooh
In my opinion, an EDC—as opposed to specialist or heavy-duty tools—should be convenient first and everything else second. If, as the name implies, it's expected to be carried every day, then being optimized for that purpose should be a given. So if a light forces you to jump through hoops just to avoid a dangerous accident, it's probably a poor fit for an EDC.
That being said, having 1st and 2nd gen SC600s, I've never had either of them turn on in a pocket. That could be because I never put it in the same pocket with objects small or sharply angled enough to depress the button—not because I'm that safety-minded, but rather because I don't like it when something gets tangled in the clip or the lanyard (mine is a loop), or when the light itself makes it hard to take out whatever else it is there.
vadimax
Vilnius, Lithuania
Mine lives in a pocket alone. Something from the outside has managed to “penetrate” the leather coat and make a direct “hit” on the switch. Probability is miniscule, yet it has happened :shrug:
gk1610
Vietnam
I made leather holsters for zl h603 lens avoid a keys or anything, I think you can do the same thing.
Tachead
Northwestern Ontario, Canada
A dangerous accident? They are flashlights, not handguns man:crackup:. The worst case scenario with a light with thermal management in your pocket is a slight burn or maybe a damaged pocket lining and you will likely notice, pull it out, and turn it off before that even happens. Now, if placing a high output light in a bag, especially if it will be left unattended, then I would definitely lock it out.
vadimax
Vilnius, Lithuania
Well, I’ve got a Maxpedition 4” flashlight sheath. I guess it will settle accidental switch on issue:
BTW, SC600w HI fits it perfectly.
Cobraman502
Here is a pic already taken, if you need any more just shout and will take
Based off the size difference, glad I went with the SC64c. Much better run times with larger cell and almost double the output.
Tachead
Yeah, it really doesn't look that much bigger considering it has near 4 times the capacity with the 18650. I am just considering getting the 53c for a new bedside light but, I am not sure if its worth it with my 64c on the way.
ven
Manchester UK
Thank you sir, I really appreciate it:thumbsup:.
No rush but, if you have a chance could you take one with the 53 right next to the 63 please. Thanks again man.
Here you go
The size difference for me is quite noticeable in hand, already the sc63w feels small but does sit nicely. The sc53w if anything does not sit as nice/comfy/natural in hand, imho the sc63 or sc64 in your case makes more sense. Certainly if there is no need for a smaller/lighter flashlight(bedside duty) and could benefit from being a little larger in size(easier to grab, bigger fuel tank).
The sc63 and sc64 are very very compact as is, unless the buyer is uncomfortable with 18650 chemistry or simply prefer AA form/fuel.....................imo 18650 makes far more sense in several ways.
Why have i got a couple of AA ZL's? Well good question as i prefer the 18650 fed by a good way. Well in short i saw them for sale, thought i would try them out, the xp-l2 4000k hi cri really tempted me of the sc5c mkII(not to mention the new UI). Then the sc53w again the 4500k xp-l2 pushed me over the edge(new UI again). Then i do like the design of the sc53w over the sc5c as well.................simple as that. Right now, the sc53w is in my coat, the sc5c in my fleece.
