Luminescent
- Joined
- Jun 26, 2007
- Messages
- 399
The Olight/ITP Titanium EOS A3 AAA – First Look
ITP has produced an amazing little light for an incredibly reasonable price.
There are now three versions –
- Anodized Aluminum
- Stainless Steel
- Titanium
I was so impressed with the original EOS A3 light that I immediately purchased the Stainless Steel version when it became available.
I have just received the Titanium version, and am happy to report that it is built to the same high standards.
The Olight(ITP) EOS A3 Titanium basically offers the weight of Aluminum (only 9 grams!) with the strength, scratch resistance, and durability of Stainless Steel.
All three lights share the same electronics and optics, and share the same maximum output and regulated multi-level output options -
- A low that is low enough to insure an amazing 30 –50 hours (depending on the battery type) and is still bright enough to easily read a paperback book.
- A very nice useful Default MEDIUM level that really is noticeably lower than the HIGH level and noticeably higher than the LOW level. Wow, imagine that!
- A nice bright HIGH level with amazingly good throw for a tiny AAA light. Forget all the sour grapes garbage you might have heard about how the 80 lumens claimed isn't 'real'. In both throw and ceiling bounce tests, the ITP EOS A3 is as bright as any light I own that claims a similar 80 lumen output INCLUDING FENIX.
Let's compare the performance of my Fenix LD01 Stainless to the ITP EOS Stainless and Titanium
BEAM QUALITY
ALL of my ITP lights have very high quality orange peel reflectors that give absolutely PERFECT beam shots with amazingly good throw. These tiny AAA light have some of the best beam shots of any light that I own (best by far in an AAA light).
My Fenix LD01 arrived sporting the worst beam shot of any light that I have purchased that cost over 10 dollars, in the last 10 years. I got it replaced, and the replacement was still not perfect. I have since rubber armored the LD01 and installed an added diffuser. The light now has a beautifully wide even floody beam that is ideal for close up work, but still has enough throw to fill a moderate sized room. Good to know my investment wasn't a total waste.
AVAILABLE LEVELS AND RUN TIME
My ITP lights all have a nice ultra long 30 to 50 hour run time low level. Aside from the long run time, this lower level is very useful when you intentionally don't want too much light (like when you don't want to zap you're your night vision) Output on the ITP EOS A3 is very well regulated throughout the run time until the very end, where there is a couple hours of diminishing output to let you know that the battery is dying. This is EXACTLY how you would want your light to behave, good regulation, but at least some warning. The incredibly long run time in low, could be a life save in an emergency like Katrina, where you might have to rely on the same battery for several days use. This is the BEST run time and most useful LOW level of any multilevel AA or AAA light that I own.
My Fenix LD01 has a LOW level that is only barley lower than the MEDIUM (default) level, and as a result it's way too bright to preserve your night vision, and doesn't give much longer run times. Even the eight and a half hours claimed by Fenix is a ridiculous exaggeration. The LD01 falls out of regulation in barely 4 hours and then limps along in dimmer and dimmer "moon mode" so that if you make it to eight hours at all, you will barley see enough light to even tell that the light is turned on. This is the WORST run time and usefulness when set to LOW level of any multilevel AA or AAA light that I own.
PWM
Both the ITP EOS A3 and the Fenix LD01 use PWM. The LD01 does use a higher frequency so if you are very sensitive to PWM the LD01 might be a better option (though if you are that sensitive, you will probably want to find a light that uses no PWM at all). Personally, I don't notice the PWM of either light, though I used to occasionally notice it on my LOD (which uses a very low PWM frequency).
VALUE
The standard Anodized Aluminum Fenix LD01 is over TWICE as expensive as the equivalent standard ITP EOS A3 in Anodized Aluminum. (~20 vs ~40+ dollars)
My Fenix LD01 Stainless light was also about TWICE as expensive as the competing ITP EOS A3 Stainless (a little over 50 dollars shipped vs a little less than 25 dollars shipped).
Let's compare the new exotic Titanium ITP EOS to the most basic standard Anodized Aluminum LD01 -
Olight(ITP) EOS A3 Titanium -> Going Gear 44.95 – 10% CPF discount = 40.46
Fenix LD01 -> FenixStore 44.95 - %8 CPF discount = 41.35
This means you can own an exotic TITANIUM EOS A3 light for LESS than Fenix's lackluster LD01 in plain old aluminum.
(this is assuming that you add a couple of needed minor purchases to your GoingGear order to total than 49 dollars so GoingGear also gives you free shipping)
Sorry Fenix, but if you put a LD01 on the table (aluminum OR stainless) and a Olight/ITP EOS A3 in pure Titanium right beside it, and let me choose, I know which one I would pick to walk away with.
Since I have already PO'd the Fenix Groupies, let me raise my sights a little –
You put a Surefire Titan and an ITP EOS A3 Titanium on the table, and I still know which one I would pick up.
The Titan
(You think I'm crazy? You can re-sell the Titan to some hopeless Surefire nut, buy Three EOS A3's in Titanium, and pocket a few hundred in change!!!) :devil:
[FONT="]-[/FONT]Luminescent
- Anodized Aluminum
- Stainless Steel
- Titanium
BEAM QUALITY
PWM
VALUE
The Titan
