bcwang
A power supply can give a more stable voltage, but what voltage is correct for batteries? Fully charged NiMH is more like 1.4 volt each.
The best would be a curve of current draw with different voltage, but it is a lot of work for a 5 mode light and next problem is that I have not found a good way to get a stable low ohmic connection from the power supply to the flashlight.
Another thing that could be done instead. With a power supply you could vary the voltage and see the current draw at different voltages. Then you could see if the circuit is more efficient at particular voltages or just higher vs lower voltages. It would be nice if the circuit was the same efficiency throughout it's voltage range but I kind of doubt it. This is of course assuming the brightness doesn't vary with the voltage which I would hope it does not since it's supposed to be constant current at the output side.
According to selfbuilds review it does not last 1.3 hours, only 1:05 hour and it starts with a slightly higher output on fresh batteries.
Does this mean slightly higher voltage gives slightly brighter output even though this is supposed to be a current regulated flashlight? Or is it simply from starting with a cool emitter it's brighter and then it drops as it heats up to a steady temp?
