jellydonut
The journey of an LED kid into the world of warm, glowy wire lamps.
I started out having seen nothing but your garden variety D-cell lights, Maglites and Minimags. The relatively rabid fanbase of the A2 made me consider adding the light to my lineup. Long story short, I ended up picking one up at the MP and I now have nine of the things in short order.
Like any light, it's so boring to keep it stock.
The A2 fits nicely in the hand - no two ways about it. The clip might be of the bezel-up carry variety, which means I don't actually use it as a pocket clip - but it can be used for keeping the light in place in a bag or on a belt or similar. It also works as an index point when gripping the light.
One thing that had to go immediately on all my A2s is the annoying lanyard ring. If your A2 is new you can rely on the 'break-away' feature of the lanyard to allow you to pull it off using a piece of cord. If, however, like my first one it is an older A2 you might find yourself pulling the loop off and having two useless plastic c-clips stuck to your light afterwards. I had no choice but to use pliers and force them off somehow. I unfortunately scratched the anodizing in the process.
The Valiant Concepts tailstander/switch protector in Delrin is an excellent addition to the A2. If you decide to go for one and you find the standard plastic ring impossible to remove.. Use acetone or nail polish remover on it. Pour a little in the interface between the tailcap aluminium and the plastic ring, let it sit a little and then unscrew it using needle nose pliers and some righteous anger at the people who glued the ring shut in the first place.:thinking:
First post kept for posterity and for making sense of the thread:
What comes out and what goes in
Light and power, of course.
The first A2 I bought already came with just about everything an A2 needs. In this photo the sanded LEDs with GITD goop and LumensFactory HO-A2 lamp are visible. I added some rechargeable AW IMR 16340s to the mix so I could play around without burning away my CR123 stock. The stock LEDs are overdriven and their lifespan is shortened by doing this, but I don't really care all that much, I'll have an onion ring to replace them with soon enough anyway.:nana:
The HO-A2 lamp is, to me, a wholesale improvement over the standard MA02 lamp assembly. It seems subjectively whiter, the hotspot seems rounder. The beam is full of irregularities and such, more so than the standard A2 as the bulb is unfrosted, but to me it doesn't matter. The beam looks horrible on a white wall but I can't recall the last time I needed a beam that looked nice on a white wall. The LF bulb has great throw for such a little light. All my LED lights are P60 size or larger and aside from the extremely overpowered ones and the Hound Dog they don't throw as nicely as the little A2.
Bodywork
I hope you won't hate me for rambling so much about this light but it is a lovely piece of gear and deserves to be rambled about.:naughty:
Hey guys
First time in this forum. I'm kinda intrigued by the A2 - I've gotten a recently kindled love for lights that are several lights in one.:naughty:
Before I go searching for a used A2, are there any readily available drop-in bulbs that are somewhat brighter than the stock bulb, yet retain the ability to run on CR123s and the A2's regulation? I'm a bit intimidated by the high-end incandescents and their requirement for lithium manganese rechargeables.
Given the incandescent lamp's lack of cooling needs as opposed to LED, shouldn't it be possible to put a powerful lamp in a comparatively small light like the A2? (let's not mention battery life, at least to start with) Or is the current draw/2xCR123 the limitation? Given the huge fanbase this light has I'm surprised there aren't more crazy mods out there.:ironic:
I've been reading through the mammoth A2 threads but I can't seem to find anything but the discontinued Strion kit (which is barely brighter to boot) - anyone?
