powernoodle
Picked up one from opticsplanet.com. The name reminds me of Pizza Planet from Toy Story 1, but that is neither here nor there.
This is not so much of a review as it is just a couple of pics.
The Strion LED is a little thinner and longer than the SF 6P. Aluminum body with tail switch that operates just like the Polystinger LED: momentary hi, with constant-on hi-med-low, and double click for a fast strobe.
A quick darkened basement test shows the Strion LED to have a much fatter (and therefore less intense) spot. At 30' on the wall, the Strion LED looks to my eyeballs to be about half as bright as the Polystinger LED, but too great degree that is because its smaller reflector is less throwy, and its cranking a few less lumens (160 to 185 with the Polystinger LED). The Polystinger LED is an awesome light, and the more I use it the more I like it. It really throws. The Strion LED is not so throwy, and (subject to real outdoor testing) seems more geared toward short to medium distances.
The Strion LED uses the Strion (incan) charger. The Strion (incan) and Strion LED each have a lithium-ion battery with the same part number, but they are not interchangeable. The Strion LED's battery has a metal tail contact, whereas the Strion (incan) battery does not. It can be left in the charger 24/7.
First impression is positive, though I might be wishing that it was a little more throwy. But you aren't going to get monster throw from a sub-1" reflector. The Strion LED is small enough for belt carry or EDC, but you'll have to come up with your own holster.
Definitely a step in the right direction from the incan flavor IMO.
