The Surefire Backup
The test lights:
Surefire Backup ...1x123
McLux III PD-S (from the first wave)...1x123
Muyshondt Nautilus Q5...1x123
Malkoff P60 Q5 dropin in a Surefire frankenlight...2x123
Fenix P1 Lux III (a dinosaur!)...1x123
Fenix L1D Q5...1xAA
Here is the set up:
Beamshots were taken 22' from the target wall, centered on a window backlit by city lights- no white walls here! The target wall is 13' wide, the top of the window is 7' 8" high, and the window itself is 5' 4" high. Manual settings were used on the camera to provide better comparison. The first set of pics highlights the hotspot, the second lets a little more light in to give an idea of relative spill, and the last set provides a direct comparison between each light and the Surefire Backup.
Here is the target. lights out:
and lights on:
The Surefire Backup:
PD-S:
Nautilus Q5:
Malkoff P60 Q5:
Fenix P1 Lux III:
Fenix L1D Q5:
PD-S:
Nautilus Q5:
Malkoff P60 Q5:
Fenix P1 Lux III:
Fenix L1D Q5:
PD-S vs. Backup:
Nautilus vs. Backup:
Malkoff P60 Q5 vs. Backup:
Fenix P1 vs. Backup:
Fenix L1D Q5 vs. Backup:
Thank you for the beamshots. The E1B reminded me of a true spot light. The spot diameter is just right. Have you done a run time on it?
Nothing with any accuracy...I ran it through a battery last night, I would guess that the stated runtimes are conservative by a little. At approx. 100 min. I found that there was no difference in hi/low anymore, acted like a single level. The brightness gradually diminished, not a sharp drop in level. It sat for about 25 min. on high on the table, got toasty but not hot to my hand. Held it for about 30 mins. on high, and in hand it got slightly warm.
I hope Surefire makes a two cell version of this light, same levels with extended runtimes....guess that will be the new defender?!
I am curious about the lux readings of the E1B.
I post readings, compared to some other lights like the SF L1, P2D Q5, etc, when I get mine. LUX meters vary from meter to meter, at least with the basic ones most of us CPF'ers use, so you can only really compare readings taken on the same meter. On my meter I'm guessing the E1B will be in the 4,000LUX range.
What strikes me most about the photos of the E1B is how "natural" the illuminated area's colors appear in the spill area. It's really remarkable how "natural" it looks compared to some of the other lights !
The E1B certainly is shaping up to be a dandy little light if the UI appeals to one......and it does to me !
Thank you for your fine review !
- my best regards.
Still wondering if the exposure was locked for the shots, or if the camera was on auto. :)
It had to be on auto, because in those photos the P1 (Luxeon) is nearly the same brightness as the Malkoff Q5. In reality the Malkoff is at least 4x as bright as the P1, if not even more.
QUOTE]
Wade this the info for this picture.
Photo Description
File Name: MalkoffvBackup.jpg (rename)
.jpgok cancel Taken With: OLYMPUS CORPORATION C-5000Z
File Size: 36 kb - 800x600 Taken On: 2008:02:07 22:04:52
Camera Make: OLYMPUS CORPORATION Camera Model: C-5000Z
Date/Time: 2008:02:07 22:04:52 Resolution: 800 x 600
Flash Used: No Focal Length: 7.8mm
Exposure Time: 0.077 s (1/13) Aperture: f/2.8
ISO Equiv.: 160 Exposure Bias: -1.70
Whitebalance: Auto Metering Mode: matrix
Exposure: program (auto) Exposure Mode: Manual
Exposure Mode: Auto bracketing
Looks to be auto, for the dark room shots.
Backup 1/13s f2.8 ISO160
PDS 1/5 f2.8 ISO160
Naut 1/5 f2.8 ISO160
Malk 1/4 f2.8 ISO160
Fen P1 1/3 f2.8 ISO160
L1D 1/5 F2.8 ISO 160
Depending on what browser you use you should look into an EXIF viewer plug in. I have only to right click to see the image information.
Here is another version...
Backup:
PD-S:
Nautilus:
Malkoff P60 Q5:
Fenix P1:
L1D:
Ah! So that's how you were getting it in the other topic. :p Can you get that EXIF viewer plug in for IE? :)
People who take beam shots should post if they are shooting in auto, or manual and at what exposure. Other wise the beam shots may mislead people into thinking one light is the same brightness as another, etc.
