The Titanium Sapphire AAA Light
brighterisbetter
brighterisbetter
Tornado Alley, USA
I bought my first one new direct from Don and it had one, but I picked up another secondhand that doesn't have one. It's not a big deal but I prefer not having the battery rattle. I tried the 'wrapping battery with post-it note' trick and it works somewhat but it could be better.
souptree
souptree
I found that the action on my first wave McGizmo Sapphire was too stiff with the foam donut installed as provided, however it was (and remains) PERFECT after I cut it in half with a very sharp knife.
I must say this continues to be one of my favorite lights and I don't go anywhere without it (along with my ever trusty PD). It's what I was looking for in a keychain light.
M
MKLight
I have the Arc version and per Don's suggestion, I took the foam ring off. I am using an Energizer Lithium cell and took a piece of Scotch tape about 1.5 inches long, folded the sticky halves on top of each other, and slid it in with the battery. I haven't noticed any rattle...and rattling bothers me.
Good luck!
MK
B
Bullzeyebill
Moderator
Staff member
CA
Another good purpose for the foam donut is that it can serve as a anti reverse polarity devise, as crude as that may sound. It keeps the flat bottomed negative terminal of the battery from making contact with the + nub of the circuit, and unless you are the perfect human being, accidents can happen, and batteries can be inserted backwards.
Bill
precisionworks
precisionworks
Benton Illinois
It surely is a handy little light :D
I finished a portable welding job (track hoe with a cracked boom) at 11:15 last evening. Both the PD-S and the SunDrop had been left at home so they wouldn't get weld spatter. The Surefire G2LED, that always stays in the truck, had been loaned to a friend. No problem until the welder-generator was turned off & I wanted to sweep the area before driving away.
Many thanks for a tiny keychain light that's always ready to use.
McGizmo
McGizmo
Maui
Thanks Barry for the testimonial as it were. But what's a little weld spatter among friends? :nana:
Peter Gransee has been making the point for years that it doesn't matter how good or sophisticated a light is if it isn't there when you need it. As flashaholics, most of us are not so likely to get caught empty handed in the dark but....
I suspect like you, I have delegated my sapphires to a support or back up role. I have two different sets of keys, one for Vespa and the other for my van. I have a Sapphire on each set so by default, if I am away from my house (were I have way more lights than I need) I am at the minimum covered with a Sapphire. I know some people rely on and use their key chain light as a primary.
Kiessling
Kiessling
Moderator,
Germany, Old World
Sapphire as a back-up here as well. One that will go where I go when on vacation as it will live through sea water and anything else :)
precisionworks
precisionworks
Benton Illinois
In fact, the PD-S did get a few BB's one day, as I was laying next to a bat-wing Bush Hog mower with a broken wheel & welding overhead. Noticed the stuck on balls as soon as I got home and popped them off with a razor blade. They left tiny discolorations, which rubbed out with a maroon Scotchbrite pad. Nice thing about Ti is that it's close to bullet proof :twothumbs
souptree
souptree
I would say my Sapphire is the light I grab about a third of the time. It is usually not far from hand. I think that takes it out of the realm of backup for me. It's become one of my primary lights! :) :wave:
F
fabienne
Indonesia
I have bought Ti Arc Kit and it seems I blew up two of the light engines provided. Any chance I could grab the light engine from here ?
H
h and k man
Is this light available looking for one
D
DDS
Hi Don,
I have one if your original Sapphire lights and I have experienced flickering from the beginning. The only way I was able to eliminate most of it was to tighten the head very tight. I have my light in my BOB and pull it out monthly for use. The flickering is much worse even after cleaning/lubing and a battery change. When I turn the light on casually it does not turn on. I then loosen the head and tighten down firmly to get it to function. Is there a remedy I can try myself to rectify the flickering issue?
Thanks Don :)
Dave
McGizmo
McGizmo
Maui
Hi Don,
Thanks Don :)
Dave
Hi Dave,
It sounds like you have an original with the ARC converter which was quite sensitive to resistance in the battery supply connections and path. There is probably a single solder blob at the perimeter of the converter board where I staked it to enhance contact. You might see if you can work that solder against the lip of the titanium head a bit and see if that improves the performance. If you want, contract me and we can sort out having you send it to me for remedy.
D
DDS
Hi Don,
Can you please email me so I can send you a pic of my LE of my sapphire to evaluate the solder blob?
Thanks, Dave
[email protected]
B
bmstrong
First post in this thread was 2009. Any planned updates to this light or configuration to bring it to 2016? (CRI, Tailstand, Two Stage)
McGizmo
McGizmo
Maui
The current Sapphire although still available with a 3 mm LED is almost exclusively requested with the GS 5 mm LED which has a more efficient LED and is of more neutral tint and reasonable CRI. The converter is also a revised version from Japan which is more efficient and stable compared to the original converter from ARC. The Sapphire still has a tail optimized for hanging from a key or other type chain and this does preclude tail standing. For hands free, I find it pretty easy to arrange the light on the key-ring with needed elevation or simply leaning it with keys against something else for needed "aim".
B
bmstrong
Understood.
T
TKC
Earth
Can I use an Enelope Pro AAA with my Sapphire? I have one of the original one, from when they first came out. TIA!!
McGizmo
McGizmo
Maui
I would like to hear from someone who has actual experience with these but as far as I know, there should be no problem or issue.
Similar threads
McGizmo
Replies
115
Views
15K
TimAckerman
TimAckerman
McGizmo
Replies
42
Views
71K
RedLED
RedLED
R
Replies
1
Views
2K
scout24
scout24
