Think it's time to finally get an x-ml P60 drop-in.........for around 20 bucks?
sol-leks
I see solarforce has a high voltage one that looks pretty nice and is only like 18 bucks......
I know manafont has a popular xml drop=in as well....
I've kinda been out of the flashlight loop for a while, any other recommendations?
Oh yeah, ideally I'd like to be able to run this off of 2xcr123 or 1x18650 but I would like to have the option for both so want something that can handle the voltage.
Also, if possible I prefer flood to throw, but not a dealbreaker one way or another.
enomosiki
Most cheap P60 drop-ins tend to accept lower range of voltages. And those that mount XM-L don't usually drive them hard, either.
Dereelight makes some decently driven XM-L drop-ins that should get you around 500 lumens OTF. If you need more, you are going to have to ask modders to make them for you. Ask vinhnguyen54 or nailbender.
sol-leks
yeah those are all a bit pricier though.......Have you heard anything about the high voltage solarforce dropin? That is the one that is looking the best to me at the moment.
hellokitty[hk]
I believe the HV dropin will not work too well with only a single LiIon. It's a buck so it needs voltage overhead.
sol-leks
looks nice, do you have any experience with that site or their dropins?
Gurthang, yeah, I saw that and that's why I started the thread
Is it a good drop-in?
LilKevin715
San Diego, CA USA
I have the solarforce 3-8.4v high-voltage dropin and it works fine for both 2 x cr123 and a single li-ion. Solarforces rated output is grossly over-stated for the 3-8.4v dropin; its only driven at 1 amp on high. Even though its only driven at 1 amp you will still get approx 300 lumens OTF, which is still pretty decent. Tailcap amp draw measurements are (H/M/L):
1 x 18650 - 0.8/0.34/0.07A
2 x 18650 - 0.44/0.19/0.05A
2 x CR123 - 0.58/0.24/0.05A
If you do the math of all the above options the result is about a 3 watt power draw. To put things in perspective a fully driven XM-L @ 3 amps will use about 10 watts of power.
sol-leks
Thanks!
Looking forward to your feeback once you've gotten it.
sol-leks
Thanks for this info. Wow, that's rather disappointing. I mean I wasn't expecting or even looking for 800 lumens, but 400-500 would be nice.
Any other dropins I should be considering? (For around 20 bucks)
LilKevin715
San Diego, CA USA
If you can go up to $30 Thrunite has a few XM-L dropins driven at 1.5A (single or multi mode). I've used the thrunite dropin and its definately brighter, but I don't really care for the stock reflector used (too floody for me). If your interested I've compared several different types of reflectors for P60 XM-L dropins, you can find the thread here.
gcbryan
Seattle,WA
Thrunite has some in the $30 range. They are driven at 1.4A. I don't think you want much more than that in a P60 host.
