mdocod
I just wanted to share this as it looks pretty silly on my small mill but it is surprisingly effective..... A 2" diameter 6 flute end mill. (yea, it's a cheapo, but it's not being used for any mission critical operations here)
I wanted to simplify and speed up one of my production steps for making battery adapters. Before I start cutting pockets and holes in a piece of a battery adapter, I always use the mill to size up the plastic parts to a nicer precision first. The saw I use to cut the plastic is very accurate for woodwork, but pretty pathetic when talking machining work.
Before, I was using a 3/4" 4 flute end mill in a 3/4" R8 collet and doing a neat dance of the X/Y table to navigate quickly over the surface of the part to true it up. This works reasonably well on smaller diameter adapters like 3xAA abreast stuff that uses just a 1.25" diameter rod, but on larger stuff, it gets more time consuming and tedious.
Long term thought here was to put an X-axis power feed on here for this operation, but that would only be worthwhile if the machine could handle a large cutter, so I figured I'd try the cutter first (it's cheaper) and I'll buy the power feed later if it worked.
I used it tonight to true up 1.25" diameter plastic rod (pass the mill right over it). DOC ranged from 0.15-0.40 for the most part. I did one where the over-size of the part was more substantial and had a chance to take a 0.075" DOC, as I recall I was running around 1200-1500RPM. The feed rate was basically as fast as I could turn the handle, Probably 24IPM give or take. No problem.
At first I was scared of the big cutter, now I simply respect it's amazing utility value and keep my fingers clear of it!
Eric
Eric
