WORD!Oh boythe toughest part of that repair is doing a decent spackling job over that popcorn paint. But once you jack the ceiling up up should be able to just screw the sheets into the existing rafters.
Yikes. Glad you caught this before it became much worse.About 10 years ago I hung a houseplant from the ceiling in my den. I noticed it was pulling the sheet rock away from the ceiling ever so slightly so I took it down. Innocent enough, right?
A few years later the roof began to leak. We had that replaced but the water caused the sheet rock to sag a little bit more. So over a few years two panels of sheet rock began to pull away from the rafters.
Today I could see the sag changing. It began to look like that soon those panels were going to fall. So today I did a temporary stabilization.
The big T stopped it from sagging any father but it's still not all the way against the rafters. That will require another method. A T like that but about a foot shorter. Then jack up the T until it has the sheet rock against the rafters.
That's the easy part. Next involves building a walkway of sorts across the rafters in order to install wooden anchor point between the rafters to fasten sheet rock screws to along the seem of the panels.
That little plant hanger to the right was in the center of a window when it should have been right or left and fastened to a rafter. It sure did cause a hassle some 10 years later.
The den is an add on room the 70 something year old homeowner before me built by himself. He had a low budget so there were some short cuts but overall he did a good job considering he was also taking care of a sick wife all while one leg was busted in Vietnam. I was told he had help building cinder block foundation and the rafters but the rest he did solo.
Anyway that's what I'll be up to this fall and winter.
Hopefully, the damage isn't too extensive. Drywall needs to stay that way. When it gets wet it loses its structural integrity. While repairing some water-damaged sheetrock at Mom's house, the extent of the damage wasn't visible until I started the repairs.Yikes. Glad you caught this before it became much worse.
I considered just fastening to rafters and may end up going that route.Oh boythe toughest part of that repair is doing a decent spackling job over that popcorn paint. But once you jack the ceiling up up should be able to just screw the sheets into the existing rafters.
The previous owner probably just used too few nails.I considered just fastening to rafters and may end up going that route.
That's another reason I want to check it from the attic but the access to the attic is a 3'x3' square so getting lumber for a walkway will be limited to smaller, shorter pieces of plywood.Hopefully, the damage isn't too extensive. Drywall needs to stay that way. When it gets wet it loses its structural integrity. While repairing some water-damaged sheetrock at Mom's house, the extent of the damage wasn't visible until I started the repairs.
I can't see where nails/screws were used on the joints. Very few have shown up over the years and those are in the center of the panels. My guess is he used adhesive along the rafters with a nail or screw here and there.The previous owner probably just used too few nails.
Your ceiling joists should be 16 inches on center. The seam of your sheet rock or plaster board should be in the middle of the 1 5/8 inch wide joist. If your house is old enough the joist will be 2 inches wide. I wouldn't go up into the attic other than to see the orientation of the joists, although they are probably running in the same direction as the siding in your picture.That's another reason I want to check it from the attic but the access to the attic is a 3'x3' square so getting lumber for a walkway will be limited to smaller, shorter pieces of plywood.
I'd probably have to build more like a crawl way than a walk way. From the ceiling to the peak is about 3-1/2' high.
I went to high school with a fellow who has a dry wall business. I may consult with him for an opinion.
Yeah, I see what you did there.We've got our fingers crossed hoping your Fall project doesn't turn into a big ole
Fall project. See what I did there?![]()
If only everyone considered me as funny as I consider myself .....Yeah, I see what you did there.
Oh it's quite possibly the start of something that may take years to complete. Maybe some fake beams and who knows what else.
You're pretty funny amigo.If only everyone considered me as funny as I consider myself .....![]()
I know. Right!?You're pretty funny amigo.
I suppose that the gravel changes with the weather too?View attachment 68964
HUZZA!
MOREBETTER.
The color changes with the weather. Both pictures accurately portray the colors. It's like magic.
Correct, Poppy! It changes from dry to wet.I suppose that the gravel changes with the weather too?
