RoGuE_StreaK
Anderson. Angry Anderson.
(hey it's your thread, you can hijack it any way you want to
(hey it's your thread, you can hijack it any way you want to)
I'm not sure who asked me to produce data to support my comment regarding HID conversions being a nuisance rather than a significant safety hazard but am I the only one that thinks this request is backwards and counter intuitive?
Accidents resulting in personal injury trigger an investigation and reporting process in which information is gathered
My comment regarding people flashing me due to the white light was an error as I should have said it was the tint of the light more cool white than the neutral or yellow of halogens.
When I see a set of cool white headlights coming at me I think HID conversions.
Accidents resulting in personal injury trigger an investigation and reporting process in which information is gathered (i.e. statements from drivers, inspection of vehicles, etc.) and if illegal headlights were determined to be the cause of motor vehicle collisions then data from these reports would be tracked at some level whether it was state or national. Based on this data, statistics would be available for additional reports or trigger regulatory or enforcement actions. Are there such reports or statistics indicating that headlights are actual causes of collisions? This is a genuine question. I would imagine that with the crowd we have here these reports would be on the list for cut and paste.
No I don't drive with the TS3000 on with the regular head lamps. There's no need as the 8700s produce more than sufficient light.
My comment regarding people flashing me due to the white light was an error as I should have said it was the tint of the light more cool white than the neutral or yellow of halogens. When I see a set of cool white headlights coming at me I think HID conversions.
It sounds like you're talking about discomfort and disability glare here. I did some light reading and while I did find a good amount on the subject, I was surprised at what I didn't find. If you wouldn't mind, could you clarify some things for me?Scheinwerfermann said:...there is a safe limit to glare intensity, above which the glare has a significantly negative direct or indirect impact on drivers' safety-related driving performance. These glare level limits are incorporated into headlamp performance specifications promulgated by a country's traffic safety agency -- these would be the US Federal Motor Vehicle Safety Standards or the Canada Motor Vehicle Safety Standards.
To begin with, at what value is disability glare no longer acceptable in general?
I haven't come across any specific values or ranges. Is that because disability glare is dependent on where in the field of vision it is located, and/or because it is more of a value judgement made with the consideration of other variables?
I also couldn't find anything about the relationship between disability glare and safety.
As for discomfort glare, that seems to be a can of worms.
Unlike disability, discomfort glare seems to be dependent on far more variables
What I didn't find though was just how discomfort glare affects drivers. Unlike disability, it would seem that the negative effects of discomfort glare are harder to pin down.
is there any more information out there on the subject?
Finally, just how much disability and discomfort glare is out there on the road today?
That's probably a very broad question, but how much of a problem is it? Is the average headlight out there right now doing reasonably well in this department? What about newly designed ones, HID and LED, and so on?
Especially the dang highbeam indicator! It's blue. Bright blue. And it won't dim with the rest of the dash lights....
There's no pat answer to that question because it is highly dependent on the level of dark-adaptation of the eyes of the person experiencing the glare as well as other significant factors. It's very situational. With any degree of dark adaptation, any/every light source in the field of vision creates some level of disability glare even if there's no discomfort. Dashboard lights are the prime example: they usually don't create discomfort, but they do degrade the driver's visual acuity (that is, they do produce some disability glare).....
The worst color, the brightest light in the cabin, right at the exact time that you don't want a competing light, when your highbeams are on....
(I use low beams as DLR on my pre-DLR Prius, and definitely want to know if the high beams are inadvertently switched on.
BTW, 7 years of DLR use of the HID lamps finally required replacement. Not too shabby.
My '65 Dart had a rather dim (somewhat easy to miss in daytime/twilight) red light-- but my '76 Corolla and later had an agonizingly blue light
harro said:Sit inside a popular euro brand of car...
Scheinwerfermann, thank you for taking the time to address my questions and the book referral. I figured that the answers would be such.
I tend to incline myself towards the European philosophy, probably in a romanticization of its “do no harm” approach
I don’t think that you were implying that I was trying to find ways to rationalize an “HID kit”
For the “HID kits” themselves, it’s actually amazing (perhaps only to me) how a superficial amount of research serves as a resounding reinforcement to their unsuitability.
Actually, some slightly older European cars had really nice setups for nighttime driving. I'm specifically thinking about an early 2000's Audi A6 Wagon with its all red-lit instruments that my father owns. Now that's a nice setup to drive behind.
Scheinwerfermann said:The European glare-averse philosophy means low beams are aimed far too low to give adequate seeing distance at real-world road speeds.
'92 VW Golf
I think the old dimmable white-to-greenish illumination that used to be more or less standard was fine.
