Thought: One Cell Extender?
Chronos
Tampa, FL
I noticed that my AW protected 17670s fit in the battery chambers of my SPY007. This led to a thought:
Dave, how about a single-cell extension body?
Pros:
- Much longer runtimes (2x17670...)
- Still fits easily in the hand
- Could use the same pickups as on the bottom of the SPY007 (same posts and attachment mechanism to attach the extension to the body, then the tailcap onto the extension)
- Could possibly even add a SECOND mini picatanny rail
Cons:
- More Ti machining for you!
- More money spent by us!:crackup:
Thoughts?
You could easily extend the lines of the SPY007 into the extension, and as noted above even add a second mini picatinny rail, if desired.
:popcorn:
Pros:
Cons:
Thoughts?
:popcorn:
A deep battery cap idea has been thrown around before but not an extension tube. I will throw it on my list to investigate.
I would like to remind everybody that the STFu converter board runs just fine with rechargeable batteries.
Cheers
Dave
:popcorn:
Wow, just think about the extended runtimes. Even though were talking more weight, I would definetely be down for such an extension !
Plus it would look cool.
I have used my SPY's with CR123 and RCR123's and they both work great. The Spy runs a long time without a battery change. Then when you thinking your low just use the battery meter and you will know what you have left. :twothumbsIts perfect the way it is.
Yep, I see all of the opinions and appreciate it.
My thought- removing the tailcap isn't easy to do, especially when in a dark place. I know I'd use a body extension as I can see me using this light A LOT, especially when walking at night, hiking, and camping. The massive runtime with 2x17670 would be welcome.
I use protected 123s in it right now. This SFTu board is amazing, Data! What is the maximum input voltage?
I forget what Wayne told me, I think around 10v.
I can replace the batteries blindfolded with just one hand. :grin2:
A deep battery cap sounds good. Not sure how the latch would work. The length would give it good "thonk" potential.
At 10 volts that would leave out using 4 primaries.
