wquiles
I am having some difficulties on outside threading that I wanted to share with the experts here - hopefully you guys can help me correct what I am doing wrong.
What I am trying to do is a project for a forum member in which I am basically duplicating this escrew:
The problem that I have is that when I am done, the peaks of the newly formed threads have been basically "squeezed" out and I end up with a larger OD than the one I started with. I don't know if this is due to the straight cutting of the threads (no 29.5Deg) or because of the actual thread cutting tip (60Deg), or what. I will post photos here in the hopes of trying to learn more
So I first get the OD to the same outer thread dia (major diameter):
I then make the edge beveled:
While I am threading, I am using a trick I learned here using super magnets holding a dial indicator. I have the parts from Modamag to get my Shumatech going, but this works in the meantime:
Then I cut and bevel the grove where the threading will end - this also marks the size of the heatsink:
So I am now ready to cut threads - I even have the thread table indicating the total cut depth and how much to cut at each pass (I am doing 20TPI):
So I set up the cutter for the first pass:
here is after the first pass:
second pass:
third pass:
fourth pass:
fifth pass:
sixth pass:
Even though I am suposedly done, when I try the head on the heatsink, it is still too big:
and when I measure the OD, I can see why - I am now at 0.822" !!!:
So I used a diamond file to cut the "tops" of the threads, and did another pass on the threads to clean-up:
and now it fits, although now the fit is a little bit too loose for my taste (looser than the actual escrew):
So what do you guys think is the problem?
Will
second pass:
third pass:
fourth pass:
fifth pass:
sixth pass:
Will
