Nice looking light. I too would prefer to have one output, wide open. I could always swap in a HipCC or a SharkBuck for that. :naughty:
Hi. Gerg. I think Op reflector will give you what you want!
Help Support Candle Power Flashlight Forum
LOL am I really that bad?even if most seems to be in a alternate language.
First off thanks to CSSHIH for the review and Thrunite for following.
"The only functional thing I don't care much for in the light is the switch (UI). I was expecting a "soft touch" to cycle modes, but you must cycle the switch completely to switch modes. With this type of switch I think a memory would be nice".
HI BigT504, UNLESS there is something wrong with your cat's switch a "soft touch" (partial button depress) will allow the unit to "cycle through the four modes. When you reach the mode you want you press all the way to lock the unit into that particular mode.
This may take a little practice till you get the feel of this superb torch.
"D wolf, I am unsure if the base is seated flat but even if it isn't I ain't sending it back to the states as I don't have a problem at the ranges this will be used at. I too have a yellow flower petal like pattern corona when shone on a close wall but I don't shine on close walls often"!
"So far 9/10 score from me. Would have got a 10 if the LED was centred and a lower low was present".
Steve, when shone at close range on a white wall my cat also shows a slight "yellow flower petal like pattern" with my supplied smooth reflector.
But on my beamshot this slight "pattern" is NOT AN EVEN corona but rather extends out from about 250 degrees from the circumference of the center hot spot. As you stated, yes I believe this is caused by a very MINUTE missalignment of the LED in relationship to the exact center of the reflector.
I also believe that IF the LED was perfectly centered (to within fractions of a milimeter) a slight pattern/corona would still exist but it would be fairly EVEN all around the hot spots circumference.
Personally it does not bother me as in real world use I can not even detect this little pattern and would not have known it existed till I shone the light (on a white wall) inside my home.
If this "pattern" bothers you you can order an OP reflector which will smooth/feather out the well defined hot spot (which will then blend in with the yellowish pattern)with no (or insignificant) loss of throw.
Enjoy your superb CAT.
hi everyone, i just bought a catapult but when i recieved it i noticed that it already had the OP reflector installed. i bought it from goinggear.com, i emailed him about it not having the smooth reflector, and he said he did not realize that there were different versions since that is what the manufacturer sent him without any options in ordering and he would try to get me right one if i wanted it. well that was a week and a half ago and still haven't got a reply and truthfully i just wanna see what this light is capable of lol. so my question is, has anyone else recieved there catapult with the OP reflector or am i just unlucky and how/where can i get the smooth reflector it's supposed to come with?
thanks for any help... and great review on the light!
I would like to be sure about how it works. Does it memorize the last mode? or Will it always start on High?... The Catapult is easy to use; it offers 3 levels of output: High > Medium > Low > Strobe. To cycle through the modes simply 'soft' or 'half' press the tailcap mounted power switch until you reach the desired level or mode then click through to lock on to that level. The Catapult is predictable and will always start on high.
Features:
. Memory mode for last output level used, with four-second separation .
At ThruNite's site Catapult description we can read:I would like to be sure about how it works. Does it memorize the last mode? or Will it always start on High?
An additional question: What does IPX-68 Water/Dust Resistance mean? I did a google search and didn't find a description for this specification IPX-68.
I'm guessing the Catapult is both IPX8 and IP68 to be technically correct.
I just received four 18650 batteries and charged them up. When I put them in my Catapult and try to turn them on it goes directly to strobe. In fact the modes are as follows:
strobe, medium, low strobe.
I made sure the battery contacts are clean too.
Could this be some sort of issue with them being "protected" cells?
