Thrunite TC20vn - Best Compact 26650 R
vinhnguyen54
Factory Link Click Here
  • Factory TC20 XHP70.2 6500K Specs: Lumen 3500, 26Kcd, 323m
  • $100 TC20vn XHP70.2 6500K + Factory UI Specs: Lumen 3700, 29Kcd, 341m
  • $175 TC20vn SST40 SD 6500K + DriverVNX2 Specs: Lumen 1700, 65Kcd, 510m
  • $225 TC20vn Triple SST40 SD 6500K + DriverVNX2 Specs: Lumen 3500, 45Kcd, 424m
  • $225 TC20vn Triple SST40 HD 7500K + DriverVNX2 Specs:
  • DriverVNX2 = USB charging eliminated
  • Excellent build quality
  • Compact but hefty 8.5oz with battery
  • Great heat sinking
  • Best 26650 flooder
  • Factory battery not included
how to take screenshots
vinhnguyen54
1st batch sold out. Funny thing is most are sold with SST40 even though its not even an option on the store LOL
70.2 is excellent though!
AmericanDissent
Vinh, what kind of lux numbers are you seeing with the SST40 version of this light? Is the Lumintop SD26vn still a better compact 26650 thrower?
klrman
Is this below correct?
TC20 = throwy (3500 lumens)
TC20vn = floody (3700 lumens)
........and, the link in the OP shows a TC20 at 3800 lumens. Is that the flood or throw version? A little confused as to what is what, but I'm really interested in the light.
noboneshotdog
They are both floody lights.
The first light at 3500 lm is FACTORY specs measured by Vinh.
The second light listed is the MODIFIED light at 3700 lm measured by Vinh.
Both would be floody with the 70.2 led in that small of a light. :thumbsup:
The 3800 lm link is what the factory states as the output. Vihn measured 3500 as factory specs with his light meter.
All measured specs are based on the results of his personal equipment.
klrman
So, what would the 3800 lumen light be then in the link, factory or modified?
vinhnguyen54
TC20vn can be had with triple SST40
Now class leading combination of throw and lumen for the size
vinhnguyen54
How is the beam? :D And what battery do you recommend for the triple? High drain (30A) required for highest output?
Highest drain cells u can buy.
Beam is flawless die to the optics
Hot spot with soft tapering
Hopefully I can do beam shot if its not too raining.
Still need to build HD sample.
LichtAn!
Hessen, Germany
What cell did you use for the 3500 Lumen spec?
Will the SST-40 ever be available in neutral white tint?
Can't wait to see beamshots. Very sexy light. :twothumbs
vinhnguyen54
Green Efest..I am ordering Purple Efest to see if I can get more output ;-)
