Thrunite TN35 (MT-G2, 2750lm) - Pictures, Impressions
gopajti
Hungary
Hello guys, my first MT-G2 flashlight arrived ca. one week ago, I would like to share my experience
Official infos
Description:
Employ Xlamp MT-G2 emitter supply max output 2750 lumen and beam distance 518meters.
TN35 combined TN30 and TN31 characteristics and found a balance between flood and throw.
TN35 could be your best choice if you are looking for a wide-using flashlight.
Key Features:
- Improved UI for more lumens
- Ultra-clear tempered glass lens with anti-reflective coating.
- Momentary forward click tactical switch.
- Strobe mode for tactical and emergency use.
- Smooth reflector for max light output.
- Highly focused beam for maximum distance
- Tactical knurling for firm grip.
- Streamlined body design.
- Mechanical reversed polarity protection design for battery carrier.
- Intelligent highly efficient circuit board design for max performance and long run time.
- Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and Outdoor activities.
- Intelligent temperature controlled light output for user safety.
Features / Spec.
LED: Cree XLamp MT-G2 EasyWhite, (Color temp: ~5000K)
Output/Modes: 0.3lm (46d), 24lm (4d), 380lm (10h), 950lm (220m), 1600lm (100m), 2750lm, Standby (1200d)
Input Voltage Range: DC: 8V-13V
Battery: 3*18650 Li-ion
Reverse Polarity Protection
Max. Peak Beam Intensity: 66940cd
Max. Beam Distance: 518m
Material: Aircraft Grade Aluminium
Surface Treatment: Premium Type III Hard Anodized Anti-Abrasive Finish
Dimension: 201.7mm (length), 79mm (bezel diameter)
Weight: 452.8g / 15.97oz
Waterproof: IPX-8 (1.5m)
Impact Resistance: 1.5m
Operation
Turn ON/OFF
Press down and release the tail-switch to turn the flashlight on/off.
1. Switch ON: Press the tail cap button down completely until a "click" sound is heard and flashlight turns on.
2. Switch OFF: Press the tail cap button down a second time until a "click" sound is heard and light is turned off.
Changing Modes
With the light turned on, rotating the Control Ring to select six levels of brightness, stand-by and strobe smoothly.
My Impressions
Pros
+ Very nice and practical packing, the carrying case quality is very similar as Olight SR9x series carrying cases
+ Excellent build quality, machining quality, scratch free anodizing
+ Nice design
+ Perfectly centered led, excellent beam quality without rings!
+ Dust free reflector and AR coated lens, both looks high quality
+ Easy one hand operation
+ Standby mode on the ring
+ NO pwm flickering, NO buzzing sound, all modes perfect! (pwm flickering free "feature" is one of the most important thing for me)
+ Well spaced modes
+ Real low mode with extreme long runtime (0.3lm, 46 days)
+ The MT-G2 led performance looks really awesome with beautiful neutral white tint
+ Good throwing capable, but the beam is versatile and suitable in lot of situations
+ Battery holder no rattle in the tube
+ You can use standard 18650 size unprotected cells easily, batteries fit perfectly. This is a good point for me (I recommend unprotected cells for advanced users only!)
+ Excellent knurling surface on body tube
+ Simple UI, left to right: 0.3lm, 24lm, 380lm, 950lm, 1600lm, 2750lm, standby and strobe
+ Tail stand / candle mode capable (stable)
+ Simple, good quality holster
+ Good price/value ratio
Cons
- No real cons for me now, maybe, the control ring could be more precise (slightly moving up and down direction)
Other comments
I would like a real-time battery indicator (Supbeam X60 solution would be perfect)
I hope more and more MT-G2 flashlights coming in near future, this led is simply awesome
Now this is one of my favourite flashlight, I hope long time reliability will be OK
Recommended accessories (batteries, chargers etc.)
Chargers:
XTAR WP2, VP1, VP2, XP4
ThruNite MCC-4
Batteries, unprotected cells for advanced users:
- Sanyo UR18650FM, 2600mAh
- Panasonic NCR18650PF, 2900mAh
- Panasonic NCR18650A, 3100mAh
- Panasonic NCR18650B, 3400mAh
- Panasonic NCR18650G, 3600mAh
Protected:
- Keeppower 2600 to 3600mAh (inside Sanyo/Panasonic cells)
- Orbtronic batteries
Now the pictures, more pics coming soon incl beamshots, comparisons with other flashlights etc
if you need higher res pls click images
ISO100, F4.5, 2.0s, WB daylight
TN35 vs Foursevens Maelstrom MMU-X3 (3*XM-L2, 1600lm)
TN35 vs Blackshadow Terminator T6 NW
ISO100 F3.5, 1.6s, WB daylight
TN35 vs Spark SL6S-740NW
TN35 vs Fenix PD35
TN35 vs Foursevens Maelstrom Regen MMR-X
TN35 vs Foursevens Maelstrom MMX with Burst Mode
TN35 vs Microfire TL2 (XM-L T6)
TN35 vs Armytek Viking v2.5
TN35 vs Skilhunt K26
TN35 vs Jetbeam DDR30 (3*XM-L U3)
TN35 vs Microfire L500R V3 NW (7*XP-G2 R4 NW)
TN35 vs Olight SR96 (3*MK-R, 4800lm)
TN35 vs Fenix RC40
TN35 vs Supbeam X60 (5*XM-L2 U2, 5000lm, ~160.000cd)
TN35 vs Fenix RC40, Microfire L500R V3 NW, Blackshadow Terminator T70, Niwalker Nova MM15, Olight SR96
Lovely photos and nice light too, btw how do you find Thrunight's quality as I have ordered two off ebay and still waiting for it to arrive.
Btw what camera did you use.
Thanks
Thanks for your impressions. Great shots of the emitter.
Do you have any experience with the Niwalker Vostro BK-FA02 MT-G2 in comparison to the TN35?
Thank you guys!
Canon Powershot A630, but I would like a MILC or better digital cam with bigger sensor for higher quality pics/videos
As a photographer I'd love to see your setup for taking pics. Does that powershot have full manual controls? Your pics are always so nice. What lights are you using? Anything through a softbox or some kind of diffuser? Or separate flashes? Enlighten me :)
martinaee
yes I use full manual controls, but I don't have other photo equipments (softbox etc), I'm not a photographer. I use flashlight and one white carton paper and some tricks. Overall, I need many many working hours for these pictures.
Bass, sorry I don't have Niwalker Vostro. But I have Jetbeam DDR30, Microfire L500R V3 NW, Fenix RC40, Olight SR96, Fenix TK76, Blackshadow Terminator T6 NW, Foursevens Maelstrom MMU-X3 and some smaller flashlights.But I need more time for beamshot pics, now the weather is not good.
Great photos. I would also like to see your set up - I understand it is basic, but you get great results.
Does the TN35 have low voltage warning and cutoff? Personally, I feel more comfortable using unprotected cells only in lights with good, reliable low voltage warning and cutoff.
Thanks, nice collection.
Now I tested (2750 lumen mode) with 3400mAh unprotected Panasonic cells and I've not seen flickering or low voltage warning, but when the voltage drop ~2.8-3V I've not seen difference between 950-1600-2750lm. I not tested more time, when I removed the batteries last time, the voltages was 2.6-2.7V. This is too low for longer test. (as you know 3400mAh cells voltage range 2.5V-4.2V).
Thanks for the review! So it seems to have just a bit more lumens and lux than the TN30?
Probably a silly question but does de doming the MTG2 work ok? I was looking at getting the new TN32 or the TK75; I like the over lumens with still decent throw of the TK75 but I love the control ring and lover modes of the TN series. This light would be my light if dedoming it put in the range of the TK75! :)
second post updated: added pic, TN35 vs DDR30, MMU-X3, Blackshadow Terminator T6 NW, Olight SR96, L500R V3 NW
(I wrote wrong cam settings on pics, "F2.0, 4.5s", correct settings was: F4.5, 2.0s, I will update pics later)
added new beamshots (check second post)
TN35 vs
- Fenix RC40
- Microfire L500R V3 NW
- Blackshadow Terminator T70
- Niwalker Nova MM15
- Olight SR96
distance ~60m
A thank you gopajti for the longer distance pics!! Very great indeed! I'm really enjoying my SR96 but as the lumens bug has it, I'm always searching... To have it throw further would be great - but really for fun purposes, as 250-300 yds is pretty good... And the spill and balance is great! Cheers!
Outstanding pictures as always gopajti,i always love your threads,they are very special:) thanks for sharing.
I have a tn35vn and love it,not tested fully yet as in UK its not dark till after i go bed:fail: so until i get on a camping trip(or stay up late :laughing: ) i wont see what 3500lm of mt g2 looks like in a field.........
I really like the UI ,very user friendly and a nice sized light too,great package and a great tint from the mtg2 as well:)
