At last, my neutral white TN36 bundle arrived this week! 🙂
Some impressions, thoughts: I like it very much, I find the build quality to be really nice, the battery carrier is well designed, and the nw tint is also pretty good. I also like it that the electronics let the light run on very high output, without switching to a lower level after a few seconds. 🙂 Of course, I think thermal regulation is a must in lights of this category, and price range.
Ok, some of the "negatives": when loaded with 4 batteries, it is heavy, not really pocketable; with the addition of the lanyard attachment point, the light became a bit longer (when comparing it to the Zebralight S6330, I just can't figure it out, how they made it that much shorter, while both of them use same length 18650s and the reflector depth is also similar); the modes are a bit simple - while it's not bad, there is nothing fancy, like customizable brightness levels, sos, etc.; a good beacon mode would have been much better than strobe; the blue light on the switch should also operate as a beacon when the light is switched off - activated by a hidden button combination, for those that don't like it; the switch is not recessed enough to avoid accidental activation, like on the Zebralights, or protected, like on the Lupines (double click to turn on); the spot is darker in the middle, not perfectly uniform, but that's only noticeable when shining the light on a white surface; no battery level check, voltage readout or that kind of stuff.
Interesting stuff: when examining the four parts of each emitter on the lowest light level, two of them are yellowish, and two are purple-blueish.
To sum it up, I like the light very much and have no doubt that it is a very well engineered high-tech piece. But it's a bit too simple for those who want some of the above mentioned extra features.
