Before I give you my lux numbers for the forward clickie, BTW they weren't impressive to me.
I want to show you a jig I bulit to take my lux readings. I made it out of scrape oak plywood. The flashlight sits on two pieces of wood parallel to the flashlight.
The flashlight is little over 1 meter from the other piece of oak plywood that sits perpendicular to the flashlight. I account for the thickness of my lux meter.
The hot spot of the beam will hit the piece of wood perpendicular to the flashlight. BTW this is a beam shot hot spot of my Olight M20 R2.
It's very easy me to find the hot spot of the beam.
This is how I always take my lux readings. It's very easy and fast to do. Just charge the batteries and off you go.
__________________________________
Left, Single Level Forward Clickie, Right, 2 Level Reverse Clickie
Left, Single Forward Level Clickie, Right, 2 Level Reverse Clickie
These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected Black 18650's and AW's Protected RCR123's which were fully charged.
These readings are the 2 level reverse clickie.
Tiablo A10 R2 WC, 18650 - 21,300 lux @ 1 meter
Tiablo A10 R2 WC, 2 RCR123's - 21,730 lux @ 1 meter
Dereelight DBS V2 Q5 3S, 18650 - 20,767 lux @ 1 meter
This is the lux reading of the 1 level forward clickie.
Tiablo A10 R2 WC, 18650 - 22,910 lux @ 1 meter
Not very impressive IMO. My beam shots below tell the story.
All beam shots below used freshly charged AW Protected 18650's.
The Tiablo A10 R2 WC is using the 1 level forward clickie.
Left, Tiablo A10 R2 WC, 18650, Right, Dereelight DBS V2 Q5 3S, 18650 @ 96"
Left, Tiablo A10 R2 WC, 18650, Right, Dereelight DBS V2 Q5 3S, 18650 @ 96" Stepped down exposure
Left, Tiablo A10 R2 WC, 18650, Right, Dereelight DBS V2 Q5 3S, 18650 @ 96" Stepped down exposure. This is the stepped down version of the 2 level reverse clickie.
All beam shots below are using the Tiablo single mode forward clickie.
Tiablo A10 R2 WC, 18650 @ 146' or 44.5 meters
Dereelight DBS V2 Q5 3S, 18650 @ 146' or 44.5 meters
Tiablo A10 R2 WC, 18650 @ 210' or 64 meters
Dereelight DBS V2 Q5 3S, 18650 @ 210' or 64 meters
Beam shots taken against buildings. At this time distance unknown.
Tiablo A10 R2 WC
DBS V2 Q5 3S
Tiablo A10 R2 WC Stepped down exposure
DBS V2 Q5 3S Stepped down exposure
