ArmyTek
All Armytek Tiara discussions in one place.
You are welcome.
Armytek Tiara A1 Pro v.2 XM-L2
2 versions: Pro and Regular
Pro – constant light brightness regardless of low battery voltage, advanced operation and a removable tailcap with magnet for fixation on iron surfaces.
Regular version is notable for easier operation.
Incredible brightness for the flashlights of such size
Effective electronics enables to get unbelievable 370 lumens brightness running only on one power source, saving compact sizes of the flashlight.
Tiara A1 – the brightest headlamp on the most widespread AA battery, Tiara C1 – the smallest headlamp on CR123A battery.
Well thought -out body ergonomics and reliable mount
Solid body without long wires, weak rubber connectors and unnecessary boxes provides fail-safe flashlight operation even in extreme conditions.
Comfortable headband for reliable fixation on the head and convenient continuous usage.
Wide flood light 70:120
Effective TIR-optics with wide light angle 70:120 for even area illumination at the distance up to 65 meters and no effect of «tunnel vision» even during continuous use of the flashlight.
Easy operation by side switch
Side switch on the head for quick and easy one-hand operation, without shifting the flashlight in the headband.
Armytek Multi-flashlights
You are welcome.
