Timer PIC?
mpteach
Im building a led light with a blue illuminated tact switch. Im using a AMC7135 for high and a resistor for low. The lithium polymer will be charged by a Max1551.
I would like to set it so that a normal quick press turns the light on high mode but a slow press of a couple seconds in length will turn it on low mode instead and of course another press turns it off. High mode should output low if its on while pluged in to the charger. I believe tact switches usually need debouncing.
Is there a simple timer chip I can use to do all this or do I have to learn how to program a PIC or something like that?
Yes, PICAXE, and you don't need a programmer (burner). A serial port in your computer and a couple of resistors is what you need to transfer your program from computer to PICAXE.
An small PICAXE-08M would to the job.
Read Driver microcontroller hacking thread.
