I used to be quite into knifemaking and all the knives made out of titanium 6AL4V test out at about 45 on the Rockwell C scale. I don't recall anything about forging it to a higher hardness, but most of the makers were using the stock removal method anyway.
When you say strength, that means different things when you have different uses for it. If you want it for a cutting instrument, it's better off if you harden the tool, but if you will be prying with it, it may be better if it was more flexible. If you really want to spend a few more bucks, you can send it to a heat treater like Paul Bos out on the west coast. I use him for heat treating my knives, but be fore warned that he charges by the inch and may not be tempering titanium at all. Look him up on the web and see what info you can get. I can't because of the firewall at work and that is a restricted site for me. Let us know what you learn.
