http://www.taschenlampen-forum.de/threads/review-armytek-dobermann-pro-xhp35-hi-warm.55289/
by Kof3
Excerpt regarding runtime and regulation...
"With optimal cooling, the lamp runs in Boost mode (Turbo 2) 14 minutes at approximately 1200 lm before it switches down. This operation takes about 26 minutes before the lamp remains in Firefly1 (0.1 lm). The battery then had a voltage of 2.85 V.
In the event of a lack of cooling, the temperature control jumps in. This ensures a rapid downshift of 1200 lm. After 9 min. The luminous flux settles at about 640 lm and remains at this level for about 45 min.
The CC mode (Turbo 1) keeps what it promises. When cooling, the lamp runs constantly at 670 lm for 64 min before it starts to turn down.
Without cooling, the lamp also starts at 670 lm, whereby the temperature control intervenes and the luminous flux is throttled within about 20 minutes to still bright 640 lm. From minute 50 to 60, there is a step-down, which should be due to the temperature regulation, before 60 minutes at 640 lm and this power is held for eight minutes. This is somewhat unpleasant, but in view of the other good regulation is not worth mentioning."
Dr.Meter LX1010B generic Luxmeter
Box: PS108
Uni-T UT210E Stromzange
Battery: Samsung INR18650-30Q Roh cell @ 4.17 V (resting time 20 min, termination 50 mA)
measured after 30 sec (ANSI FL1) - ambient: 23 ° C / 39% rh (and especially for our nice user flummi: 1015,3 hPa @ 95 m asl)
If you need more throw and longer runtimes, it seems the older XPL-HI is still the better choice.
by Kof3
Box: PS108
Lighting | Luminous flux in lm | Brightness in lx | Current consumption in mA |
Firefly1 | > 0.1 | 2 | 2 |
Firefly2 | 1.2 | 32 | 13 |
Main1 | 28.8 | 805 | 81 |
Main2 | 129.7 | 3500 | 315 |
Main3 | 296 | 8000 | 775 |
Turbo1 | 641 | 17800 | 2160 |
Turbo2 | 1208 | 30300 | 5760 |
