Have had TnC Keylux AA for a number of years,
Have an original 200ma (red) that takes a regular or rechargeable 1.2vAA.(as does HaNat 350ma)
This flashlight has an LE that does not screw in and is powered by a 1.2V AA battery. The on/off can be operated with the head twist which is different than the later two versions. (tail cap twisty).
700ma,Seoul Multi level, 350ma HaNat, 200ma Red
TnC 18650, SFCR2, SF AA, Keykux AA 700ma
The SF series and latest Keylux need a tool (see pictures)to remove and add Light Engine cannisters
SF adapter (TnC);LE cannister screw into adapter and adapter screw to barrel and head. AA, cannister screw directly into body. LE cannisters do fit in Either SF or Keylux AA and can be multi-level with Li-on or single level; some work with 1.2V AA. (single level ) Note that SF has Surefire E adapters (McGizmo Aleph) and other for Lego.
700ma Seoul Flu-Pic with cannister tool...........LE's screw counterclockwise
Beam Shots and comments, next post!
jeffb
jeffb
