Too bright...
georges80
Sunnyvale, CA
So, had a customer ask about a custom hyperboost configuration to drive a nominal 100W LED array.
Been doing some testing today with part of the challenge in keeping the 100W LED cool....
So, here's some pictures of today's fun for your viewing pleasure...
100W input power with about 94W going to the LED (yep, around 94% efficiency)
Power supply (input into the hyperboost) about 100W
Hyperboost on its heatsink - basically just sitting on some thermal pad against a hunk of aluminium
After 10 minutes, the heatsink temperature
and the hottest area on the hyperboost driver, pretty impressive considering it's just "sitting" on the thermal pad
Water getting pretty warm in the LED bath
The 100W LED array bolted down to a hunk of aluminium having a swim
cheers,
george.
Nice efficiency! And thanks to that, nice board temp. What application is this going to be used for George? (if they dont mind you saying). That a bridgelux array?
I can't comment on the application or the specific LED array.
I think the supplied array is just a test sample, basically something I could use as a load to prove out the modified hyperboost capability. The array is running with a Vf of just over 30V driven at 3A. It is stupid bright 🙂
Yeah, I was very pleased with the efficiency, obviously having a close Vin to Vout is helping a lot. I did drop down the Vin to just under 20V (5A input) and was still getting a bit over 90%.
cheers,
george.
How low could you go with input voltage? What about 7.4 or 11.1v 14.8v?
It's a boost driver, so as input voltage goes down, input current goes up. For hyperboost I recommend a maximum input current of 5A. So based on that requirement you can calculate how much power can be fed into hyperboost for a particular input voltage.
Obviously if you tried to get 100W output from only 7.4V input that would mean over 100W/7.4V = 13A
So, assuming 5A max input, then for 7.4V the max input power would be 5 x 7.4 = 36W, for 14.8V it would be 5 x 14.8 = 74W etc etc.
cheers,
george.
