Pixel Hunter
- Joined
- Oct 9, 2014
- Messages
- 29
My wife and I want to replace a pair of 20+ year old 3 D-cell MagLites. They are just too big and I’m not happy with the uneven beam patterns. Plus the incandescent bulb/alkaline battery tech is just old-school now. We want good general purpose lights that we can use for:
We prefer to favor US manufacturers whenever possible. Even still, I have ~25 options on my Amazon wishlist from SureFire, Streamlight, Foursevens, EagleTac and MagLite. So that’s why I’m hoping to get some advice/recommendations from the “flashaholic” community who probably have a better understanding and experience than I ever will.
The lights would likely spend large amounts of time sitting unused. Therefore, I’m not sure whether primary or rechargeable is the better battery to go with. Then, what size/style battery to go with…
My inner Tim Taylor/Jeremy Clarkson demands “more power!” simply so I can show off. But I also want something that can be efficient for the tasks stated above. Hey… is it wrong to want to peel the paint off the ISS?
I’m thinking of either buying a pair of nice small-to-medium lights that my wife and I can use. One would be stored in the kitchen drawer and the other in the daily driver. Or I’m thinking of buying a couple good minis, to put one in each car, and a single small-medium light to keep in the house.
For added info, I’ve also included the “questionnaire” from the sticky post in this forum:
Brick or online – I need them by Oct 18.
2) Budget: An easy question, but you may change your mind after answering the rest! 🙂
__X__Up to $100. – Under $50 would be ideal, under $75 is acceptable, and my max has got to be $100.
3) Format:
__X__I want a flashlight (hand held/self contained).
4) Size:
__X__TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
NOTE: My wife and I prefer to favor US companies whenever possible, so brands like Fenix, Nitecore and others are not being considered at the moment, though I would consider non-US brands if the product justified it. It looks like SureFire, Streamlight, and Mag are US with primary manufacturing/assemply in the US, while Foursevens and EagleTac are US companies with Chinese manufacturing. (Correct me if I’m wrong.)
__X__I don't know/I need more information on power sources.
NOTE: I originally thought that a rechargeable flashlight would be ideal, but with the limited use they would see, perhaps a primary battery with a long shelf life would be best. But I’ve also considered lights that accept multiple types of batteries. AA’s are a good generic option, as they are cheap and I have a tone of both primary and rechargeable AA batteries in the house. However, I understand that lithiums like the C123 are much better for power density and longevity.
__X__I don't care
__X__I want an indoor "blackout" light (15-50 lumens)
__X__I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens).
__X__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
NOTE: I don’t really know what I need/want. I’m sick of my 3xD Mag-Lite’s size and weight, and the fact that whenever I dust it off to use it, it seems dim and the inconsistent beam pattern leaves dark spots or is too narrow.
I don’t know
__X__90-120 minutes (Runtime is moderately important, but still not critical)
__X__3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
__X__Very Important (Camping, Backpacking, Car Glove-box).
__X__I don’t know.
__X__Other, please specify__I’m not very fond of the old AA twist-head incandescent lights I’ve had in the past.___.
__X__I don’t know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
__X__Other, please specify__willing to consider other materials___.
15) Water resistance
__X__IPX4 (Splash resistant)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
__X__Emergency kit (long standby periods)
__X__Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
- Power outages
- Camping
- Nighttime outdoor activities (like the corn maze we’re going to next weekend)
- Working around the house/car
- Etc.
3) Format:
4) Size:
6) Manufacturer:
__X__I don't care
I don’t know
__X__I don’t know.
__X__I don’t know.
