Still trying to grasp the initial self-discharge topic.
Suppose I take a typical NiMH battery, let's say 2500mah. Doesn't matter if it's hybrid or not, since, from what I understand, the initial self-discharge happens in both kinds; it's just the discharge afterwards is different.
Let's assume the initial self-discharge is 20% for the first 24 hours.
A fully topped off charge of the battery would, theoretically, "fill it" to 2500mah. 20% of that is 500mah, so after 24 hours of sitting off the charger, the battery would be 2000mah.
What if I only charge it up to, say, 2250mah, or ~90% of the capacity (that's what the Maha C808M seems to do anyway)...will there still be a 20% discharge (bringing it down to 1800mah), or would it bring it to 20% below the max, which would then be the 2000mah?
What if I only give it a half charge...ie to 1250mah? Would there be an initial self-discharge at all?
Basically at what point does the initial self-discharge take place and how long does it last?
Thanks
-Mike
Thanks
-Mike
