Tri-EDC
Colonel Sanders
Well-known member
ROLL TIDE!
If it's gotta be clipless then I'm ok with that so long as it's an 18650....gotta have some runtime in my funtime!
But I gotta ask....why no clip if it's 18650?
Perhaps a 1x18500 with a clip could be done? I think I might still rather have the clipless 18650 though. I have a 1x18650 SC60 Zebralight (it has a nice low profile clip) and it's just the perfect size for an EDC (4" long), IMO. Outstanding runtime too. It just needs to be about 3 times brighter!
easilyled
Well-known member
Middlesex, UK
Well, now I'm torn - I'd like the longer runtime of the 18650 yet the small size of the single cell version is starting to really appeal to me. I guess the real answer is 'buy both' :broke:
That's why I think that the 18500 would be a great size. Much more capacity than an RCR123 but not as big as an 18650.
As the Tri-EDC head is shorter than the SST-50 head, an 18500 Tri-EDC would in actual fact be hardly any longer than the SST-50.
18500, 18500, 18500 please Mac. :)
cmacclel
Well-known member
Boston
The current clip is designed for a body that houses a 35mm long cell. If the body / cell is any longer the clip will not work and would need to be redesigned / lengthened.
Mac
emu124
Well-known member
Switzerland / CONUS address
+1 :thumbsup:
palimpsest
Well-known member
France
The actual measurements of the SST-50 are "graceful" and provide a nice feeling in hand particulary due to the difference between the body diameter compared to the head diameter.
This difference will be less pronounced with a 18500. Even if the better runtime/capacity would be a great advantage, a 17500 would be better to not loose the original shape of the SST-50 EDC that makes this electrical torch so good looking.
flashfiend
Well-known member
Bay Area, CA
Finally got somebody on my side regarding diameter. Now I just have to convince you (and Mac) 2xIMR16340 is better for maximum brightness. Still hoping so I can get my triple satisfaction.
Btw, for those of you with tri-EDCs how is the heat on these?
palimpsest
Well-known member
France
Personnally i don't need the maximum brightness for an EDC, so actually i prefer the compacity of a shorter body with only 1x 16340. It is my default choice until i see how the light designed for 2x 16340 looks like, maybe i will change my mind then if the shapes/measurements are well balanced.
flashfiend
Well-known member
Bay Area, CA
That's why we have 3-modes for those of us who want maximum brightness.
cmacclel
Well-known member
Boston
I just performed a Test on the 18350's and AW's 18500 at a 2.8 amp load and the 18500 is out. The 18500 did best the 18350 but only by around 10%. It would not be worth it to me to redesign a body and have to stock 2 clips for only a 10% increase.
Mac
paintballdad
Well-known member
SoCal
I'm in regardless of what Mac finally decides on the final design. I'm just sorry i missed the small batch of Tri-EDC's.
cmacclel
Well-known member
Boston
Sweet! I am definitely in for an aluminum neutral.
Last question, will it run ok on low and medium on a primary?
I do not recommend using a primary as the driver can pull around 2.8 amps on high and that is WAY to much for a primary. You could use a primary low and medium but......................I would not recommend it.
Mac
Colonel Sanders
Well-known member
ROLL TIDE!
I'll bet that you're gonna test an 18650 too....:huh:
Thanks for the explanation on the clip.
Protected 18650s at 2900mah now have a maximum discharge rate of 5.8A, could these possibly be used in this light? I understand that it would probably lose a little (a lot?) lumen to IMR cells. Would make for some fantastic run time for this little monster. Thanks again, Mac. :thumbsup:
paintballdad
Well-known member
SoCal
Mac,
Will there be subsequent runs similar to your SST-50 EDC for us that might miss out on the 1st run? I have a feeling it's gonna be a stampede on Monday night.
Thanks
easilyled
Well-known member
Middlesex, UK
I'm ready. :devil:
