Is there a boost driver that can drive a string of 3 XML or 3 P7 to 2.8A or higher Running on 2 IMR Li-ion?
basically to boost from 8V to 12V while delivering 3Amp? 3x12=36,
36/8 = pulling 4.5 Amp from 8v battery.
Assume 80% efficiency, it'll pull 5.4Amp from two IMR together.
The battery 2xIMR AW 26500 should be perfect but does such a high current boost driver exist?
Looking for a way to Run Triple XML out of Mag 2C using 2xIMR.
