Sold/Expired Triple Seoul P7 / Cree MC-E Kit for Mag D
Re: Triple Seoul P7 Kit for Mag D
I use downloads AMC7135 variety of a driver:
http://www.candlepowerforums.com/vb/showthread.php?t=201392
And running the show on 3 x LiION D-size. It's very efficient.
This is a floody setup. But it will light up the nearest couple of hundred meters of estate with that enormous flood. It's somthing else.
I'll do a tutorial for a setup like the diagram in the link and some outdoor beamshots when I get back from Prague next week.
We are looking forward to see your diagram and beamshots :popcorn:!
i think i'll be interested in 9 of those reflectors in a few weeks or so. i hope you still have some stock of them left 🙂
dann reih ich mich mal in die warteschlange ein^^
würde ein komplettes set nehmen 😉
sag grad bescheit wenn du wieder was auf lager hast
Hi!
Kann man in die Triple P7 auch deinen PWM Dimmer bauen und wie hoch ist die Effizienz von deinem Treiber? Könnte ich beides auch mit 30 Volt betreiben?
Gruß
nilsm
Wilkommen nach CPF, nilsm.
There is a requirement to post in English here, rather than other languages. CPF staff have abilities in several languages, but moderation becomes difficult and we therefore now have a rule that other languages are disallowed. You are allowed this first one, but all your future posts must be in English, please.
Today I received in my box a package containing all the kit.
This kit is beautiful and very good quality.
Bravo and thank you Wichtel. :twothumbs
Rycky
Wichtel,
I received mine on Monday, great job!
Grüße aus Bayreuth
Peter
Do you think that a 2D mag, which is finned at the head and the body, would be enouth to cool the LEDs?
if i am right the heat sinkt should have a surface of ca. 500cm².
So theoretical even a bare 2d Mag should do the job.
am i right?
My kit just arrived this morning. The kit looks good. Can't wait to build the light. Just need some p7's now. :candle: Thanks!
Der Witchel I'm interested in this kit, please send me a PM. Thanks.:thumbsup:
I don't suppose anyone has first hand experience with the difference between DerWichtel's reflectors and the Boom-S? I'm just curious if the beam pattern is about the same, or more throwy with DWs?
A couple of quick questions before I start building:
How is the driver intended to be wired? I assume black is a common ground; of the red and red-black wires, which goes to power and which goes to the LED?
Second, you previously said that the output could be varied by changing one of the resistors (marked on the one I ordered). Would the output go down as the resistance goes up, or the opposite (output reduced if resistance reduced)?
Thanks.
Oh, glad I asked. On mine, the wires are red on far left, red with black stripe in the middle, and black on the right (positions corresponding to the picture). So the black wire is actually the positive for the LED. Normally, I would associate red or white wires with positive, black with ground.
Good to know on the resistor. That should make it pretty easy to do a two-stage switch if I decide that a potentiometer is too much trouble.
Thanks.
