trit vial behind an aspheric lens
StarHalo
California Republic
Search for "tritium torch" over in the Marketplace, they come up for group buy from time to time; it's basically a plastic case that has a tritium globe behind a magnifying lens.
trout
yorkshire / England
Cheers I should have worded it better
I meant using trit vials instead of glow paint next to the leds in an aspheric light
is this doable with OK results
CKOD
It would definitely work, but due to GITD epoxy having a higher initial brightness than trits it might not be as impressive. Obviously tritium has the advantage of running longer. If you wanted the best of both worlds, i'd go for putting in a bead of GITD epoxy, then with tweezers, gently push the trit into the epoxy, let it set, then coat it with NOA and cure that for a bit of extra protection. Maybe even different a different color epoxy then the trit just for effect.
