Activity of 1 g of T = 9,600 Ci = 3.55 x 1014 Bq
9.6 kCi = 9.6 Sv
Dimensions of tritium vial in glowring are 1mm x 22mm or 1.78ml in volume.
Density of hydrogen is 0.00009 gm/ml. Since tritium has 3 times its atomic weight, the density of tritium would be 0.00027 gm/ml.
density * volume = mass, so in a tritium glowring's vial there is 0.00048 grams of tritium, which extrapolating from my earlier calculations contains 0.004608 Sv of radiation.
From the following effects of radiation:
2.5 mSv/yr is the natural background exposure (average). Note: 1000 mSv = 1 Sv
5 mSv/yr is the maximum permissible dose-equivalent
~ 1 or 2 Sv causes acute symptoms (loss of hair, bleeding, etc.)
~ 4 Sv results in death with a probability of 50%
> 10 Sv is lethal
We can conclude the amount of tritium in a glowring, if it were to be broken and fully absorbed by the human body (which seems unlikely), would cause a dose of approximately 4.6 mSv which is about twice what you recieve from natural radioactivity sources.
If you ate 976 glowring's tritium, you would reach the LD50 for tritium exposure and likely die.
If you ate about 250, your hair would fall out.
My recommendation is to not eat glow rings. /ubbthreads/images/graemlins/grin.gif
(assuming all my math is correct)
9.6 kCi = 9.6 Sv
> 10 Sv is lethal
