Doing some testing on a 6 month old trustfire 14500. Probably charged it 10 times in its life, and was using it in a Nitecore d10 until the cutoff.
If I fully charge it, and then drain it at 0.7 amp rate, I can only suck 100mAh out of it before I hit 3 volts. If I drop the rate down to 0.3 amps, I can only draw about 2-300 mAh before it hits 3 volts.
Is this about par for the course? Suprisingly, when I go to recharge them at 0.7 amps, it only takes a few seconds to get them back up to 4.2 volts. This is the behavior I'd expect from a bad cell for lipo, but I'm not too familiar with li-ion. This is my only battery until I get my next order in.
