TrustFire MC12 1000 Lumens Dual-use Headlamp, 16340 Light, Rechargeable
SWM
TrustFire MC12 1000 Lumens Dual-use Headlamp, 16340, Rechargeable
  • TrustFire MC12 is a beauty,tiny high performance magnetic rechargeable headlamp & flashlight.
  • Max output 1000 lumens with high operability and high reliability. With intelligent temperature control system and low voltage warning indicator.
  • MC12 is a perfect magnetic USB charge EDC flashlight and headlamp for dual-use, intelligent circuit build inside,constant current,constant brightness. with a faster 5V 2A magnetic charging cable and it could charge directly with power bank, computer etc. you can charge it conveniently.
  • MC12 is powered by 1*16340 battery(included) and using magnetic charging technology. On the top with one-click mode switch button and magnet function at the Tail, IP68 anti-dust waterproof rating and 1 meter drop test which is a great choice for both home and outdoor.
Max 1000 Lumens
EDC Gear
Tail Magnetic Fixing - Free Your Hands
5V 2A Magnetic USB Charging
Specifications
  • MC12 has 5 working modes High>Middle>Low>Moonlight>Strob
    :wave:
    -- High output mode: 1000 lumens; 105m beam;runs 65 minutes
    -- Middle output mode:200 lumens; 46m beam; runs 160 minutes
    -- Low output mode: 60 lumens; 25m beam; runs 9 hours
    -- Strobe mode: 1000 lumens
    -- Lockout mode can be activated on the side switch for accidental triggering protection, along with a low-voltage indicator underneath
If you are looking for a small, lightweight, pocket 16340 light, that's it!
TrustFire MC12 US URL
TrustFire MC12 UK URL
TrustFire
