wolfy
Just purchased a Trustfire SST-50, was intrigued by the low cost and similarity to the Jetbeam M1X. It came in today, and as I havent seen much in the forums about it, thought I might put up a couple pictures and a quick comparison.
So here is a couple pictures of it next to a Jetbeam M1X and the Thrunite Catapult V2, the two lights I have which are most similar.
Reflector view
The M1X and the Catapult have a better build quality, with better attention to detail, but for AU$88 (delivered) I think it looks pretty good.
As can be seen in the picture above, the Trustfire has a SMO solid aluminium reflector similar in shape to the M1X but smaller in diameter, the Catapult V2 is deeper but similar in diameter. The Trustfire has a fairly tight hotspot similar to the Catapult, but the spill of the M1X. Early indications suggest it out throws the M1X. The photo below was taken with exposure set to 2 stops under exposure, white balance it set to auto, Catapult V2 on left, Trustfire SST-50 and Jetbeam M1X on the right. PS: hotspot photo taken with lights almost 2m from the wall.
It runs between 6-12volts, with its body setup it can run on 4xCR123A or 2x18650, so the M1X has more battery options. There are five modes, High, Medium, Low, Strobe and SOS, all selectable by quickly turning the tailcap switch off and on (or half pressing it), and it remembers the last setting. The LED assembly is fairly easily removable, also the tailcap doesnt fit the the body with the extension removed so no 3xCR123A.
Im quite pleased I bought it now, cant expect more for AU$88.
Reflector view
