\"Turbo Charging\" a flashlight
During the past year or so I've spent some time playing around with LEDs trying to make a bright flashlight. LEDs are fine when you need a small amount of light, but I've decided what I really want is a small flashlight that is rechargeable and puts off a lot of light.
I can't justify purchasing one of the ~$100 commercially available flashlights so I've been experimenting.
I have some lithion-ion cell phone battery packs that are 7.2-8V and about 1250mAH capacity. The packs are a little taller than a D-cell and a little wider (the pack is made of 2 cells that look like big AAs). I've found I can put 1 in most 2-D cell flashlights and solder in some wires. Of course I need to change bulbs too something beefier. My first bulb experiment is using the Maglite 5-cell kryton bulb.
It puts out a LOT of light...and heat. The first flashlight I tried it in had the lens cover too close to the bulb and it started to deform after 5-10 minutes. Next, I bought a cheapo $1 flashlight where the lens cover was further away. This time the reflector started melting.
Today I bought a $5 Eveready flashlight with a thicker reflector. Don't know if it will work since it is still plastic.
Does anybody have any thoughts? These battery packs won't fit in a maglite since they don't have enough room diameter wise.
I'd like to find a "cheap" 2-D cell flashlight with a metal reflector and lens cover that can take the heat.
Thanks.
Thanks.
