<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Doug:
are you saying that the picture of the "2LED Bulb (L), Probulb (R)" is correct, the brighter one IS the 2LED?!<HR></BLOCKQUOTE>
From the looks of things, right at the center it is, then as you move outward the Probulb is brighter.
I understand, when you say that the hotspot is wider for the Pro... hmm... perhaps a little focusing would help ... but thanks for the pictures !<HR></BLOCKQUOTE>
I suspect that is kind of the heart of the matter. I think the reflector on the TL II compliments the normal focusing of the LED packaging.
Since the Probulb doesn't have any focusing aspect to it, you only get what the reflector provides.
It's interesting to see what a vast difference the TL II reflector and the Maglite reflector make.
The Maglite is very focused and the resulting beam is very bright, but it stinks if you don't want a spot light. If you look at the first couple of shots, the ones of the Probulb with and without the spacer, I think you get an idea of what type of focusing is possible with this reflector and the Probulb. I don't think you are going to get a much better beam.
My conclusions: The TL II works pretty darn well in it's original form. The TL II + Probulb suffers a bit in beam formation, but it is much whiter and somewhat brighter (just not at the very center), however, the TL II + Probulb is better IMO than a 2-3D Maglite with or without the Probulb.
What we really need here is a C or D cell Arc LS.... Hint, hint...
-john
