D
**DONOTDELETE**
Guest
I just got a used Turtlelight recently. I like the flashlight body but the reflector made a dark circle in the middle of the light at long distances. I took a blue LED I bought from B.G. Micro and filed it down flat on the top to make it shorter and remove the rings (makes a nice diffused light). I filed the sides down a little too. I soldered it and a resistor in a bulb case and hot glued around it for shock resistance. The blue light in the Turtlelight looks good. I can let the kids use it and not have to worry about it getting broken or wet and they like the color too. I put the Turtlelite LED in a 4 C Cell Maglight. Wow, talk about a spotlight. With the Maglight's reflector the LED puts out a super tight beam that can be seen across a long room in full daylight. It's not a great path light but it would work great for looking around the yard at night.
I've never seen an LED light that goes so far.
