Help Support Candle Power Flashlight Forum
already did and calibrated itTry replacing the battery in the meter.
The weird thing is, is that there are coming up as 5.8 volts, almost 6 volts. Is this because they are not being used like not being drawn power from and just sitting there
or is there something I am doing wrong with the multimeter.
No, resting , open circuit voltage should still not be more than 4.2 volts.
Possible but unlikely.
If you have fresh battery, DC Volt range and leads plugged in to meter correctly there is nothing to do wrong.
You say older meter, how old? Is it digital display or moving coil with a needle ?
Sent from my iPhone using Candlepowerforums
TrueHello Xzel87,
As cells age they warm up during charging. I prefer cells to remain cool and think you may be taking some additional risk when a cell heats up.
Yep.In absolute terms, "too hot" is when the cell vents. Usually the cell is too hot to hold in your hand just prior to this.
If the cells are free, why take chances? Just use the cells that stay cool and move on.
on the other hand if you are curious you can continue to use those cells and set up a charging area that can handle a rapid venting with flame incident.
