alfreddajero
I was lucky with mine.....it seemed that all eight of the cells work properly.
How can you tell which ones are better than the others, short of doing a runtime test, given that they all were harvested and found to be at save voltages?
Read post #8.
That seems pretty reasonable to me. Of the 5 or so non-functional Dell laptop packs I've taken apart so far I've only tossed 4 cells. two were 0V, two were 1.xV both were paralleled sets. The remainder of the cells were 3V+ and charged right up to 4.17 on my Pila and have held within .1 of that for months after.Actually, I posted post #8 hoping that someone would let me know if I was on the right track. I'm certainly no authority.
--flatline
Removing the solder tab on anode with a plier might break a contact inside! I lost a lot of cell with this method! :hairpull:
I do this now with a dremel, grind with caution the 4 weld points.
I just pulled a bunch of these, but scuffed the wrapper of a few. The shrink wrap is incredibly thin and delicate. Can anyone think of a way to repair the wrapper?
Yes the shrink wrap on laptop cells is VERY thin and delicate. Its been the cause of a couple fires that I have experienced, during cell extraction.
I just used 3M clear packaging tape.
Note that you can use the cell, but it will direct contact -B to the body of the light. So there is the chance that you will not be able to turn the light off. depending on how severe the damage is.
I hope you'll indulge me with is probably a dumb question.
I have a toshiba battery pack that contains green Sony cells. I've not disassembled it yet so maybe the answer to my question will reveal itself when I do but I'll ask anyway.
as with the sanyo cells in the images posted in this thread there are no markings on the shrink wrap of the Sony's to distinguish anode and cathode.
how does one determine the positive and negative terminals of each cell ?
Here's the recipe I use to determine which cells are healthy enough to be usable. If any of you see something that could be improved, please let me know (I think I'm probably being too conservative, but don't really know for sure).
1. measure cell voltage. if it's less than 2.5v, throw it away.
2. charge the cell. if it gets hot during charging, throw it away.
3. measure cell voltage off the charger. verify it's between 4.1 and 4.2v.
4. wait 30 minutes
5. measure cell voltage. if it's fallen less than 4v, throw it away. Otherwise record the voltage.
6. store cell for 3+ days in cool, dry place.
7. measure cell voltage. if cell voltage has fallen more than .1v from the recorded voltage, throw it away.
Any cell that hasn't been thrown away by the time I'm through with step 7, I keep and put into my regular cell rotation.
EDIT: I'm no authority, but since nobody tried to correct me, I'm willing to assume that there's nothing obviously wrong with the above recipe.
--flatline
